tire lettering
    November 2003
tire lettering
Posted by rudedog on Friday, July 15, 2005 9:42 AM
Hi gang.A while ago,someone talked about using whiteout paper & glue. What type of glue,how long do you let the glue dry,& do you rub over the paper or let the glue do the work ?Thanks ahead,rudedog
"...That's an order,not a debate topic , Sergeant Rudzik..."
Posted by Anonymous on Friday, July 15, 2005 5:50 PM
I've never actually heard of this, but it seems to me it would work the same way as applying gold leaf. Brush glue onto where you want the leaf to go. Apply the leaf and let dry, then brush off the excess. I'm not sure about the white material used, but the glue is probably a white glue or craft glue.
    January 2003
Posted by gburdon on Friday, July 15, 2005 9:03 PM
rudedog;
Try finding typwriter correction tape at a local office supply shop. It is a self-adhesive whiteout on a pliable tape. You get about 15 pieces to a pack here in Ontario for $1.50. One piece is enough to do approx 4 sets of tires in 1/24 scale.
Simply brush the raised section of lettering with a superglue or similar. Apply the tape over top and burnish it on with an eraser of a pencil or similar smooth applicator. Seal it with a light spray of dullcote (Testors or similar) and you're done.
Hope this helps.
Cheers;
Gregory
VETERAN - (Noun) - Definition - One who signed a blank cheque as: “Payable to The People of Canada, Up To and Including My Life."
    January 2003
Posted by yardbird78 on Saturday, July 16, 2005 1:38 PM
Greg,
Thanks for the tip on lettering. I will have to try that.
Darwin, O.F. Alien [alien]
The B-52 and me, we have grown old, gray and overweight together.
    November 2003
Posted by rudedog on Saturday, July 16, 2005 6:52 PM
Thanks Ryan & Greg,It's gotta be a better method Than painting when your a shaky coffee addict !!!, rudedog
    June 2004
Posted by clfesmire on Saturday, July 16, 2005 8:03 PM
You'll excuse me for going slightly off the topic, but I wouldn't consider using the typewriter whiteout because the whole deal hinges on how well you apply the glue to the raised letters. I would occur to me that using a white paint pen would be easier to control and be done with it in one step.
