360 spider carpet / flocking application
Posted by Anonymous on Tuesday, August 16, 2005 3:00 PM
i am working on tamiyas ferrari 360 spider and i have decided to install carpet on the floor for my first time. i have no one to guide me the right way, but the box instructions are pretty self explanatatory. however they say to use clear parts cement. i have plenty of clear parts cement, but i have a lot more elmers glue. i was wondering if i brushed on slightly thinned elmers glue, would it work the same? i cant see why it would work, but in the past the forum has been so helpful, so i thought that i should ask, to see if anyone has any suggestions or alternatives. thanks... DXB
Posted by Anonymous on Tuesday, August 16, 2005 3:29 PM
Donny - I have used thinned Elmer's with great success. I would highly recommend that you experiment with a piece of styrene before you do the interior of the Ferrari. The key for me was thinning it enough that it would go on smooth and not run. It was a trial-and-error kind of thing, but I did eventually have very good results.
Moderator
Posted by Matthew Usher on Tuesday, August 16, 2005 4:00 PM
I use Elmer's all the time, and I usually thin it about 1/3 with water and apply it with a paintbrush.
If you make a mistake, a little warm water will remove the paint and the flocking without hurting the paint underneath so you can try again.
Matthew Usher at FineScale Modeler
Posted by Anonymous on Tuesday, August 16, 2005 4:42 PM
thx for the help. i figured elmers would work just the same!
