Good topic mate. Now to open the useless info vault at the back of my head......
The carbon fibre patterns change depending on the machine you are building. And different machines might have multiple different patterns and shades on them. The different patterns you see result from the materials and processes used in the Carbon fibre production. Here's a quick background to carbon fibre composites (skip this if you know this stuff already):
Carbon fibre starts it's life as a plastic called PAN. It goes through a process and ends up as a black woven fabric. Depending on different steps and processes used here, is what gives the CF the different patterns. It is then added to a plastic resin to give it rigidity and to hold the fibres in the correct orientation. At this stage, it can also be woven with different materials (eg. Kevlar) to give a combination of useful properties (high strentgh and penetration resistance with kevlar). Too much info???
Now onto the part that's useful for modelling......The only way to tell what kind of CF was used on the machine you are building is to look at pictures. One thing to remember with CF on models is, the direction the lines run in is actually important on the real machine (not on all parts, but especially on suspension arms etc). Try to look at reference and copy the way their CF runs.
The thing about some carbon fibre is that it can look different depending on the angle you look at it from. From one angle it might look like the stripy type of CF, but from a different angle it looks spotty. I noticed this alot on the Williams FW-24. I used Scale motorsport's 1/24 plain weave decals for mine (it would suit alot of modern F1 cars). It's good because it looks like black decal with a very faint pattern on it.
I don't think the black and grey striped decals are very accurate. The grey is usually too bright (especially on Scale motorsports decals). It would be more accurate if it was black with dark grey lines. I usually give these decals a coat of Tamiya Smoke paint to tone them down a bit if they look too "liney"
. On the rear wings supports of the FW-24 I used clear orange to give the CF a bronze appearance like on the real cars.
On Moto GP bikes, I noticed they use alot of the spotty type CF for the fairing pieces. So I use these types of patterns on the inside of fairings. But again it all depends on the bike that you're building......
As you've probably figured out, I like using decals to achieve the effect most. If you take your time, they are pretty easy to use. I tried the spray through the mesh method once, but it didn't turn out very well (it was probably my fault, one part turned out well, but the other 3 didn't
There could be a whole book written on this subject, but I'll stop it here. Hope I didn't bore you with a whole heap of useless info. And, I know someone will come along and point out all my mistakes........BTW, this is my longest post ever
........Sorry.
