TAMIYA - Cement (40ml)
Posted by Anonymous on Tuesday, January 31, 2006 6:48 AM
I've been looking for this stuff on websites for days with no luck, is this for sale in the UK. I've also been to afew model shops in my area with no luck.
Is there any Substitute for this with the same results? I've been told that some glues can harm your model so I don't want to get the wrong stuff.
Thanks
Steve
Posted by Anonymous on Tuesday, January 31, 2006 8:16 AM
I usually use this one:
Humbrol glue also works very well:
None of them will harm plastic. They just melt a bit the join to make it stronger. Unless you soak plastic parts with this kind of cements you should not have any problems.
Regards
Posted by Anonymous on Tuesday, January 31, 2006 9:55 AM
thanks for the reply, where do you buy them from?
I live in UK
    August 2005
Posted by eizzle on Tuesday, January 31, 2006 10:07 AM
You might be able to order it directly from the Tamiya website? Have you checked there?
Colin
 Homer Simpson for president!!!
Posted by Anonymous on Tuesday, January 31, 2006 5:15 PM
modelsforsale.com here in the UK have both types of Tamiya glues in 40ml. Select glues/paints in the left column then select manufacturer... Tamiya.........I have purchased quite a lot from them and can confirm that their service is excellent.
Les
Posted by Anonymous on Wednesday, February 1, 2006 4:23 AM
thanks bloodhound, I've ordered some from there!
Steve
    March 2004
Posted by DanCooper on Monday, February 6, 2006 3:05 PM
Hey Steve, which Tamiya glue did you order ?  I ask because the of applying it is slightly different.
The one with the white cap, you apply to the pieces first and then put the pieces against eachother, the one with the green cap you hold the pieces against eachoter and than let a drop of the glue flow in the seam.
On the bench : Revell's 1/125 RV Calypso
    January 2006
Posted by Agamemnon on Tuesday, February 7, 2006 5:44 AM
And remember that less is more in glue. If you put too much liquid poly in before squeezing the bitz together, the spillage will do damage to the plastic, turning it into moosh. Whenever you pull the brush out of the bottle, run it across the rim a few times so that any excess flows back into the bottle instead of flooding the model.
Look at these people, these human beings; consider their potential! From the day they arrive on the planet, blinking, step into the sun, there is more to see than can ever be seen, more to do than... no, hold on. Sorry, that's The Lion King. But, the point still stands... leave them alone! -- The Tenth Doctor
