'32 Ford Engine color
Posted by mastercarp on Friday, August 11, 2006 2:33 PM
    Hi all.  I'm starting to build a '32 Ford and I let my wife pick the color for the body- Tamiya Pink with Hot Magenta flames.  My question is this: Does the engine need to be painted a certain color (i.e. Ford Engine Red) or can it be painted a color that doesn't clash with the pink so that I can leave the engine visible?  Thanks for the help.
Chris
Scenic Carpenter's Creed: If they can see that, they're not watching the show.
    May 2005
Posted by Bgrigg on Friday, August 11, 2006 6:55 PM
 It is typical of hot rodders to paint the engine block to match the exterior color. In a few occasion they are painted in a contrasting color, but usually only when the exterior color is a flat black or dark blue. A friend of mine has a '32 Ford Roadster in Lemon Yellow, with a Flathead V8 painted to match and it looks wicked!
So long folks!
Posted by jhande on Friday, August 11, 2006 9:42 PM
Hey Chris,
In your case I would probably go with the Hot Magenta to match the flames.
Another option...
If you are going to have a lot of chrome and added detail (such as wiring) on the engine, you could even paint it flat or semi-gloss black.
-- Jim --
"Put the pedal down & shake the ground!"
    August 2007
Posted by doc-hm3 on Wednesday, April 23, 2008 8:56 AM
  Jim, do you know of a good aftermarket source for engines and parts like in your pictures? Thanks
        Charlie
All gave some and some gave all.
fox
    January 2007
Posted by fox on Wednesday, April 23, 2008 9:37 PM
One source that comes to mind is Detail Master. I used them for gauges and steering wheel for my '53 Chevy Street Rod in the 50's Group Build. I know there are a lot of others out there if you check around the forum.
JimCaptain [4:-)]
 Main WIP:
