'67 Chevelle
    April 2006
'67 Chevelle
Posted by oleander13 on Friday, October 19, 2007 12:13 PM
Hey everyone,
 I normally build 1/48 aircraft, but a lady at work asked me to build her a '67 chevelle and paint it Malibu Blue with Black interior.  I picked up a can of testors Nassau Blue Metallic and that is the closest match I can come up with.  As far as using the paint though, I'd like to decant it into a clean Jar and cap it off.  Will the paint hold up inside the jar or will it begin drying?  Will I have to decant the paint before each coat I put on or can I just spray it into the jar all at once and use it as I need it?
I'm afraid to spray it in and have it gunk up on me in the bottle.
 Thanks for the help in advance!
 -Mark-
Things could be worse. Suppose your errors were counted and published every day, like those of a baseball player. Life will always throw you curves, just keep fouling them off... the right pitch will come, but when it does, be prepared to run the bases.
    January 2005
Posted by daveinthehat on Friday, October 19, 2007 1:03 PM
I cut a drinking straw in half and slide it around the opening in the nozzle. Spray it against the side of a cup. Don't let the straw go into the paint or it splatters all over the place. I let it sit for a few minutes to let the propellents escape and then just put it in my airbrush. I never had any problems with it getting thick or any problems with it. I've been doing this for quite a while. I really stink at painting with a spray can.
Try a test shot first if you've never done it before.
    April 2006
Posted by oleander13 on Friday, October 19, 2007 1:48 PM
Thanks for the answer Dave.  I have decanted paint before, but never stored it for a any number of days.  What my question was is if I decant the entire can into a jar, use some of it in my airbrush, put it up for a day or two until the initial coat dries, then get it out of the jar into the airbrush again, will it dry up or act like a normal jar of model master paint for example.
Thanks for the answer in advance.
Posted by proosen on Friday, October 19, 2007 2:44 PM
Don't know about the Testor's paint but I've decanted Tamiya lacquers into film-jars and kept them for months without any problems. If they get a little thick over time you just thin them with some lacquer thinner and it's ready to use again. Try to get the cans from Fuji-film, the transparent ones, the lids on them snaps in place and holds very tight.
Niclas
Edit:
Came to think about something, before you put on the lid for good on the jar. Take one and poke a little hole in it. Put on some silly putty as a safety valve so that the lid wan't pop off when the paint gasses out. Let it be like this over night and then you can put on a lid without a hole in it.
