scratch building carrier deck
    September 2009
Posted by burner12 on Tuesday, September 29, 2009 12:04 PM
I need some help on how to scratch build a carrier deck with a catapult and JBD. I have never done this before so this is a first for me. I am curious as to how hard it is in putting in the tie down points and what to use as a base? I have looked at that website that sells bases flattopsandmore.com and he's too expensive fro me. Also I couldn't find any carrier deck made by Verlinden. I plan to make it as cat 3 and have some deck figures. I just don't know how hard this will be to do? The main plane will be a E model Hornet.
Posted by waikong on Tuesday, September 29, 2009 4:24 PM
I don't know what scale you need and what era, but Eduard has 1/48 scale wwII era decks for under $10.  It will fit a dive bomber type plane nicely.
    September 2009
Posted by burner12 on Tuesday, September 29, 2009 5:33 PM
Oh sorry. It's for 1/48 scale Nimitz class deck.
Posted by waikong on Wednesday, September 30, 2009 9:47 AM
eduard and flightpaths makes 1/48 us modern carrier decks, but I think they are of the printed hard-card type. So depending on your requirements they may not fit, but are only around $10.
if you want to print your own, you can try this link over at ARC http://www.arcforums.com/forums/air/index.php?showtopic=171755&st=60
Tom Modelworks makes PE tie downs for around $15 or so if you want to build your own deck from scratch and just add the tie-downs, as those would be much more difficult to scratch build.
JustPlaneStuff makes one in resin, but its in the $30+ range, I don't know if thats over your budget.
    September 2009
Posted by burner12 on Wednesday, September 30, 2009 11:11 AM
Do you think that amount of tie downs from Tom Modelworks will be enough for a 2ft by 2ft base?
Posted by waikong on Wednesday, September 30, 2009 12:22 PM
Looks like it to me, but then I'm no modern carrier expert. Here's a link
http://www.greatmodels.com/~smartcart/cgi/display.cgi?item_num=TMW0213
maybe you can tell by the picture
    August 2005
Posted by EdGrune on Wednesday, September 30, 2009 2:08 PM
The TOMS US Carrier Deck tie downs are the WWII "Greek Key" strips which were installed on the deck in place of every so-many deck planks.   The current tie-downs are five pointed bars which mount into depressions in the deck.
EDIT -- Oops the previous post shows a different item than is shown on the Toms website catalog.  The previous has stars
White Ensign Models has a PE fret with the stars as well as the Greek Keys
Check the photo database at navy.mil for an idea on the spacing beteen the tie-down points
