cockpit harness
cockpit harness
Posted by icit on Sunday, December 13, 2009 8:11 PM
I've been searching the forum site for info on how to make cockpit harness'/seatbelts from masking tape, any ideas on where to look for a how to article or can someone explain it for me. Thanks
icit
Posted by Don Stauffer on Monday, December 14, 2009 8:42 AM
I do it one of two ways.  Sometimes I double it over, creasing along the centerline, then cut to width.  I do that mostly in larger scale, like 1:32.  For smaller scale I often just cut a stripe out of the tape (tape pressed against a cutting mat.  The single layer then has adhesive back to stick it to seat.  For small scale I use PE fittings.  For 1:32 I often bend fine craft wire into fittings.
Also, for 1:32 (the double layer method) I run the strip through the buckle and double back upon itself to create the "adjustable" section.  For the smaller scale I usually dispense with the adjustment piece.
Masking tape has a color very close to one of the colors of the old military belts.
Posted by icit on Monday, December 14, 2009 11:52 AM
Thanks Don, I've been playing with that very idea and getting some very good results. I wish I could afford to build in the 1/32 range but  the truth is I just dont have the space for it.
icit
Posted by Don Stauffer on Tuesday, December 15, 2009 9:05 AM
Yeah, I have cut way back on 1:32.  Current 1:32 project (using masking tape belts, too) is a racer (Laird-Turner) so it is pretty small for a 1:32.  It isn't scratchbuilt (except for interior- I trashed the whole kit interior and did it myself).  In general though I am moving towards smaller scale.
    August 2007
Posted by Reload on Friday, December 18, 2009 7:52 PM
I use the tape method all the time and really like it. Here is a tip, the tape takes paint very well. I paint mine Testors wodd and then dry brush with a light sand or tan. Works fo rme.
Brent
1 VP - PPCLI 89-92 A Coy RED DEVILS
 I mean, I had fast motor cars and fast motor bikes, and when I wasn't crashing airplanes, I was crashing motor bikes. It's all part of the game. — Sir Harry Broadhurst, RAF, 12 victories WWII
