Steve,
I'd like to see your Spirit, but I can't get to your photobucket by the links you provided.
If you go down and click on the pencil icon at the bottom of your post (Edit Post), you will be able to edit your post.
Click on the "insert image" icon and put your URL in the field provided. Hit "insert" and that should do it. If not try a different link associated with your picture. Photobucket gives you 4 and I don't remember which one it takes (I use ImageShack now)
I'm looking forward to seeing your build.
If you still need some help, yell out.
