CargoLux 747-8F over the threshold
    January 2021
Posted by fuzznoggin on Monday, March 22, 2021 6:52 PM
Revell's 1/144 scale 747-8F.  Aftermarket leading & trailing edge flaps from Shapeways.com.  Custom made base.  Illuminated with help from EvansDesigns.com circuit board and Led's.  Paints by Tamiya and Model Master buffables. Landing gear modified by adding 4mm to the struts and tilting the wing and belly gear accordingly ( 57 & 7 degress ).
 FinalVideo
Posted by keavdog on Monday, March 22, 2021 8:19 PM
Fantastic!  How did you make the stand?
Thanks,
John
    May 2011
Posted by Real G on Monday, March 22, 2021 10:15 PM
Very cool!
“Ya ya ya, unicorn papoi!”
Posted by jeaton01 on Tuesday, March 23, 2021 1:15 AM
Very cool indeed.  Fighting off the urge to say Awesome!
John
Posted by gregbale on Tuesday, March 23, 2021 5:52 AM
jeaton01
"Give in to the power of the Dark Side...."
Awesome!
Greg
George Lewis:
    August 2015
Posted by crown r n7 on Tuesday, March 23, 2021 6:52 AM
beatuiful, did those livery decals come with the kit? I have ordered from a few decal sites and the cargo lux are on b/o.
 Nick.
    January 2021
Posted by fuzznoggin on Tuesday, March 23, 2021 7:06 AM
The stand is made from 3/8" acrylic rod.  The cradle is made from a 1/8" piece of acrylic sheet that as cut into the curved shape.  A 1/8" slot is cut into the top of the rod and the cradle piece fits into that.  Pretty basic but a bit tedious cutting the curve from the sheet.
    January 2021
Posted by fuzznoggin on Tuesday, March 23, 2021 7:12 AM
crown r n7
Yes they are the Revell decals.  The "cutaways" are rather transparent requiring the red/white/blue striping to be trimmed out, otherwise it will show through.  At least you'll have some extra red and blue to fix any areas that may require touch up.  Be careful when clear coating the finished decals.  I used a light mist Tamiya clear and it actually started to eat away at a few sections of the tail.  Perhaps a chemical reaction from the MicroSol softner used earlier.  Anyhow, the leftover red striping pieces saved the day ~ thankfully!  If I had to do the clear coat again, it would have been with Alclad's aqueous clear versus a lacquer.
    October 2019
Posted by Tanker-Builder on Tuesday, March 23, 2021 7:37 AM
I have to ask;
     Are the Decals showing the Cut-Aways? Very Well done Aircraft, for sure!
    January 2021
Posted by fuzznoggin on Tuesday, March 23, 2021 8:02 PM
Tanker-Builder
I have to ask;
  Thanks!  Yes the decals are showing the cut-aways
    November 2020
Posted by Buckeye2 on Thursday, March 25, 2021 11:16 AM
Nice!Yes
    July 2018
Posted by JustPlaneJon on Friday, April 9, 2021 9:34 AM
Excellent work, especially with making the setup, the leading edge flap details, and lighting. Looks great!
    May 2011
Posted by Real G on Friday, April 9, 2021 12:36 PM
JustPlaneJon
Speaking of the leading edge flaps, just what is the thinking behind Krueger flaps?  What is the advantage of rotating out from under the wing instead of just sliding out a portion of the upper leading edge?  It seems like a more complicated way to do things, but there must be a good reason.
    April 2021
Posted by Jan Davis on Wednesday, April 14, 2021 1:32 PM
Amazing! Looks gorgeous.
I'm Jan Davis, photographer and artist
    July 2014
Posted by modelcrazy on Wednesday, April 14, 2021 1:39 PM
Steve
    January 2021
Posted by fuzznoggin on Thursday, April 15, 2021 6:20 PM
Real G
JustPlaneJon
Real G
JustPlaneJon
Increased camber using this type of flap design vs the slat.  I'll leave an aeronautical engineer expound on that
    January 2021
Posted by fuzznoggin on Monday, May 17, 2021 6:25 AM
keavdog
    January 2015
Posted by TheMongoose on Thursday, April 7, 2022 8:30 PM
Beautiful! Love the lighting and the weathering!
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
