Missing jet nacelle plastic fan insert
    May 2021
Posted by chrisgil on Wednesday, May 12, 2021 1:21 AM
Newbie looking for some help on a missing part in a custom make model, missing the plastic jet fan insert, as shown, if any one can help out with a supplier :
https://drive.google.com/file/d/14yIAPEJoe5nc125POHsOCWnCHOzhk2RH/view?usp=sharing
    September 2006
Posted by the Baron on Thursday, May 13, 2021 8:00 AM
chrisgil
Hi, Chris, not sure what you mean by a custom make model, but can you tell us who made it?  Is it a commercial short-run kit, is it a scratchbuild, a kit-bash, or something else?
I ask, because if it's a commercial product, whether from a large maker or a garage kit maker (ie, someone who makes kits, usually in resin, casting in small batches, usually limited), you could try tracking down the maker to see if a replacement part is available.
If it's not commercially made, you might have to try substituting, either with a part from another kit, or maybe even scratchbuilding your own.
If this is a custom model, a scratchbuild or a kit-bash, again, if you know who made it, you could try contacting him.  If he can't provide a replacement, he could tell you the donor kit that provided the part.
Scratchbuilding the fan wouldn't be too difficult, even if it's your first time.  Just at a quick glance, I'd get some styrene strip (eg, Evergreen) for the blades, and find something to use for the hub.  Could be the nearest pointy object you have at hand (eg, an old-style pen cap, like from Bic pens), or you could even sand a piece of sprue to shape.  Use a disc of styrene sheet as the backing, and attach the pieces to it.
Beyond that, you might want to check the 3D printing sites, like Shapeways, and see if anyone makes a similar part, or, see if you could contract with someone through the site, to make one.
I don't know if this helps, but this is what comes to mind, considering the problem.
Best regards,
Brad
    September 2012
Posted by GMorrison on Thursday, May 13, 2021 8:26 PM
That looks like a Citation, scale in the 1/30 or so range.
In fact, it looks quite a bit like this:
https://www.diecastairplane.com/store/p/4881-Cessna-Citation-X-1-40.html
If that's the case, and by nacelle you mean the whole engine pod, your best bet is to either get another one from the original source, or look on  ebay for another model, or frankly display it sideways with the missing engine away.
Bill
    September 2012
Posted by GMorrison on Friday, May 14, 2021 12:02 AM
So are you just looking for the fan and the swirly thing?
If so, maybe take a photo of the one you have, and size the image to fit, print it and stick it in there.
Bill
