Dak uniform colors
    June 2006
Dak uniform colors
Posted by Tankluver on Sunday, August 25, 2019 12:03 AM
i currently have ammo Mig paints RLM 79 sandgelb, ral 2027 sandgrau , ral 7021 dunkelgrau and ral 8020 gelbbraun. Would any of these work for dak uniforms ?
    April 2006
Posted by jgeratic on Sunday, August 25, 2019 2:17 PM
Not the grey, but maybe the others ... I would use them as a mixing base, otherwise you have aircraft/vehicle paints used for clothing.   The tropical cloth varied in shade, ranging from brown to dark olive green khaki.   Throw in sun bleaching and washing, the possibilities run all the way to an off white.
regards,
Jack
    June 2006
Posted by Tankluver on Sunday, August 25, 2019 9:01 PM
jgeratic
Not the grey, but maybe the others ... I would use them as a mixing base, otherwise you have aircraft/vehicle paints used for clothing.   The tropical cloth varied in shade, ranging from brown to dark olive green khaki.   Throw in sun bleaching and washing, the possibilitiis run all the way to an off white.
regards,
Jack
yeah i realized it was all vehicle paint colors but i figured it’d be worth a shot. I was just trying to see if i could make do with what i had or if i should order the AK set
    November 2008
Posted by plasticjunkie on Sunday, August 25, 2019 11:45 PM
All you need is little bottles of Testors olive, white and tan enamels. Mix your own  shades as the DAK uniforms had a very wide range of colors as shown on the above pictures.
Here is a 1/35 figure painted with the above enamels:
 GIFMaker.org_jy_Ayj_O
    November 2016
Posted by cabrown1 on Monday, August 26, 2019 10:07 AM
One thing that was very prevalent was the field caps were almost white. The "newbies" coming into the theater would use various methods to lighten their caps so as to not look like newbies. The lightened caps stand out in a lot of group photos.
    April 2006
Posted by jgeratic on Monday, August 26, 2019 10:29 AM
Yes, there are a number of paint brands that do uniform sets.  Note the AK set shows six bottles, but is only two colours with a highlight and shadow paint for each.  Don't know if it is any cheaper, but Scala75 has a 15% off sale at the moment:
https://scale75.com/es/buscar?controller=search&orderby=position&orderway=desc&search_query=dak&submit_search=
If you don't mind mixing or intend to do just a few figures, then PJ has a good idea too.
regards,
Jack
    June 2006
Posted by Tankluver on Monday, August 26, 2019 4:06 PM
plasticjunkie
thats pretty dang good, I’m till getting back into the groove of painting again. I like your idea it also sounds a lot cheaper then buying a paint set as well.
    April 2019
Posted by Srpuln10 on Monday, August 26, 2019 4:26 PM
That's a sweet paint job. How did you get the pockets and folds in the shirt pop out like they do. Tks
2 Cor 6:17
    November 2008
Posted by plasticjunkie on Monday, August 26, 2019 6:55 PM
Tankluver
plasticjunkie
Thanks! Like old Bob Ross used to say you only need a couple of colors to mix your own. Now let’s paint some happy trees!
    November 2008
The
Srpuln10
Thanks. After the paint dried for a couple of days I gave it a pin wash of my home brew thinner and artist oil paint mix.
