Simulating 'FUR"
Simulating 'FUR"
Posted by Anonymous on Monday, April 3, 2006 6:10 PM
anyone with experience simulating fur on an animal figure?  Does that flocking material from craft stores do a decent job?  I'm doing a vintage Aurora Cave Bear and think it'd look good with some texture.  Thanks friends.
Posted by Wolfp on Monday, April 3, 2006 6:22 PM
Is it plastic.  If so you might consider using a hot iron to scribe the fur.  Also, epoxy putty could probably be used and sculpted into a fur texture.  Just some ideas.
J.B. http://photobucket.com/albums/a303/jbrunyon/
On the Bench: !/350 TOS Enterprise; 1/72 Tie Interceptor
Posted by Anonymous on Monday, April 3, 2006 9:19 PM
Epoxy is my vote. Let it set for about 30 minutes, and then use an exacto blade, with short, quick, shallow cuts, all in one general direction. As the putty sets, you can texture it finer and finer. I'd take a toothpick ot the end of a brush, and block out the sections of the fur first, and then start laying in the texture.
Posted by renarts on Monday, April 3, 2006 9:40 PM
If you are going to use putty over the existing surface, a piece of fine wire with a loop in it makes a nice fur texturing tool. The other thing that works pretty well is taking a small swatch of craft fur and laying it down and pressing it into the putty. When you lift it off.....fur.
    November 2003
Posted by goldenturtle02 on Wednesday, April 12, 2006 1:27 PM
All the above ideas sound good. I have decent results with flocking from Detail Master.  But you should practice on something that you can do without, an old car body? Mayhaps a Cougar, or a Jaguar or maybe a Mustang and lastly a Sunbeam Tiger. Hmmmm I may build a furry Jag.......
Man these blades are sharp....... Where's this red stuff coming from????
    May 2004
Posted by Colin Russell on Sunday, April 16, 2006 2:52 PM
If the kit is plastic, then you can brush-paint a little area with liquid poly cement to soften the plastic's surface.  Then use a needle in a small pin vice and quickly scribe 'fur' lines into the plastic.  Keep going till you cover the model.  When finished, take an old bit of Scotchbrite over it to remove any stringy bits of plastic and there you are ....fur!
The same technique can be used on plastic figures for dioramas to improve the quality of the hair on a human head.  Hope this helps.
Posted by m1garand on Thursday, April 27, 2006 5:35 PM
Don't forget to add purple velvet seats with zebra stripes with it. I forgot that  this is the plastic modeling forum, not a Pimp MAH Ride forum. j/k Big Smile [:D]
Best regards,
Huggy Bear
