changing heads
    March 2005
changing heads
Posted by ephriam01 on Friday, December 29, 2006 2:13 PM
i am trying to change the head on my 1/35 tamiya figure using some heads that i bought from historex but my figure looks weird. the neck is thinner on the new head than the original so my man now looks like an ostrich!!
can anyone help me with this process please maybe i should have drilled out a cavity for the neck?
aaaaargh......i should have kept it simple!!
cheers
mark
"Cuimhnichibh na suinn nach maireann. Mairidh an cliu beo gu brath."
Posted by ajlafleche on Friday, December 29, 2006 2:53 PM
Drill a hole into the torso the size of the new neck. You may need to use sveral successive bits to do this. You may also want to shorten the neck, as well. The deeper hole will make for a much stronger bond than just gluing the head on.
