Need to make lots of 1/35 gun slings.
    August 2006
Posted by IanIsBored2000 on Thursday, February 15, 2007 3:55 PM
Well, Im finally starting work up again on my Omaha Beach diorama, and realised I need LOTS of gunslings.  Can you buy sheets of PE gunslings?  if not, what ocould I make them out of? And whats the easiest way to attach them?  Glue doesnt seem to hold unless I put on a big glob, and even then, it doesnt stay.  Thanks.
"Scanlon: work your knobby hands on the table in front of you, constructing a make-beleive bomb to blow up a make-beleive world."
    September 2005
Posted by Kykeon on Thursday, February 15, 2007 4:25 PM
There are PE gun slings available, (I'd try Aber first) complete with buckles and other hardware. Try a search on Greatmodels, VLS or other online HS.
You can make your own from lead foil. I collect it from wine bottle hoods, (which now are mainly heavy-gauge aluminum foil, but work just as well). Use an X-Acto knife handle and roll it out flat on a smooth surface, (a piece of glass or ceramic tile works well). Using a metal straightedge and a sharp, #11 X-Acto, cut thin, (~.030") strips of foil. Take a look at a photo of a real rifle you are modeling to estimate the length needed and where to attach them. Buckles can be made by folding small bits of foil around the strap, glue with CA and trim excess to fit.
    August 2006
Posted by IanIsBored2000 on Thursday, February 15, 2007 4:57 PM
Where Else might I find lead foil?  Im a little too young to collect it off wine bottles Make a Toast [#toast].  Thanks, Ian
Posted by ajlafleche on Thursday, February 15, 2007 5:36 PM
I have plenty of this. E-mail me your ground address at ajlafleche@comcast.net and I'll drop a few sheets in the mail.
    August 2005
Posted by Phil_H on Thursday, February 15, 2007 7:15 PM
As an alternative, go down to your local "$2 shop" (read that as "cheap variety store") and pick up a disposable foil baking tray. You'll have enough material for hundreds of straps.
If you want to go "upmarket", you can pick up a roll of foil sheet from an arts and crafts store. (Will cost considerably more though).
    September 2005
Posted by Kykeon on Thursday, February 15, 2007 7:47 PM
 Empty toothpaste tubes work too. .020" electronics solder, available at Radio Shack by the roll, can be rolled flat and works well for this purpose. No need to cut thin strips either!
    July 2006
Posted by telsono on Thursday, February 22, 2007 5:34 PM
I have been using the foil from good quality chocolate bars. Not your Hershey bars, but the more expensive (and tastier) ones.
Beware the hobby that eats.  - Ben Franklin
Do not fear mistakes. You will know failure. Continue to reach out. - Ben Franklin
The U.S. Constitution  doesn't guarantee happiness, only the pursuit of it. You have to catch up with it yourself. - Ben Franklin
Posted by senojrn on Saturday, March 3, 2007 11:19 AM
I use strips of masking tape.  I paint the non-adhesive side first, then use the adhesive side to help me attach the sling to the weapon with super glue applied with a toothpick being the final method of attachment.  (Be sure to scrap off a tiny area of paint where your sling attachment point is, otherwise it won't stick!)  Once it is on the weapon, I finish painting, weathering and posing the sling.
