1st figure pics up for criticism
    October 2004
Posted by ygmodeler4 on Tuesday, August 14, 2007 10:52 PM
 Tamiya 1/35 that came with my M4 Sherman
This is my first fig and i think it's a good start but definately not perfect... so critisize if you want i can take seeing how it's the only way to get better...but compliments are welcome too.
Paints were Model Master Acryls and i couldn't quite find the right lighting so i'll post a bunch of pics with different lighting and angles and such so you can get a better idea of the figure.
Thanks guys!
-Josiah
Posted by ajlafleche on Tuesday, August 14, 2007 11:06 PM
Certainly not a bad start in the dark art of figures. Actually, a pretty good piece.
Some things to watch out for:
Your paints tend to run on to other color. Invest is some really good artists' brushes with fine points to do the webbing and stuff like cuff edges. (pictures 1 and 3)
I think WWII boots were brown, not black.
Looks like some paint got worn off the back of the leg in picture 1. Using a primer coat and washing the parts will help here.
A bit more differentiation between the pants and the spats would look better.
Each color looks a bit monochromatic. Try to work on highlights and shadows to give more depth to the colors. Check out armorama dot com and acrylicosvallejo dot com (englsh then "model color" for informaion on painting with acrylics.
Again, a very good start in figure painting.
    January 2007
Posted by the doog on Wednesday, August 15, 2007 1:14 AM
Sign - Ditto [#ditto] yeah, what he said...certainly passable; hey, just the fact that you're jumping into the forum with your first figure and looking for crits tells me that you'll be producing some superb dudes before long! Keep practicing, keep painting, and keep posting!
    August 2006
Posted by IanIsBored2000 on Wednesday, August 15, 2007 6:11 AM
Great start, you have the basic painting sdown really well.  Some quick drybrushing would make clothing look great, or the more advanced figure painters here can teach you shading/highliting.
"Scanlon: work your knobby hands on the table in front of you, constructing a make-beleive bomb to blow up a make-beleive world."
    October 2004
Posted by ygmodeler4 on Wednesday, August 15, 2007 8:58 AM
Thanks guys...
As  for the boots i did paint them Model Master Acryls "Leather" and they are brown in person but they do look black in the pics so I'm sorry for that...still got to figure out my mom's camera and a lighting solution.
The next one i'll practice some highlights so that one should be done in about a week or 2.
thanks again guys.
-Josiah
Posted by Anonymous on Wednesday, August 15, 2007 4:03 PM
I'll chime in, too.  Great first fig!  I remember mine being HORRID!  (they died in the Great Firecracker War many years ago...)  I just kept painting and kept reading how others painted and kept painting.  Every figure was (and still is) an experiment.  Seems like every bottle of paint is different, every brush is different...  The 2 main things, tho - keep painting and keep having fun!
    April 2006
Posted by jgeratic on Wednesday, August 15, 2007 6:01 PM
For a first time figure, it looks very good to me.  On my comp the boots do look brown.  There is a bit of sheen on the figure and investing in some flat spray will cure that.  As for highlights, you can use the dry brush method, but it's not truly accurate for folds in clothing - assuming you are portraying the light source is coming from above the figure.   If you have an airbrush, mix a lighter shade of the clothing colour and spray from directly above the figure.  This gives you a decent starting point and you can add finer highlights with a brush.
Posted by ajlafleche on Wednesday, August 15, 2007 6:14 PM
I think that would be very risky at this point in the build. That certainly would work early on when you want to figure out wher ethe highlights are, but at this point,  I think holding the figure beneath a single light source would be a better option.
    October 2004
Posted by ygmodeler4 on Wednesday, August 15, 2007 6:55 PM
Thanks for the tips guys i'll try that lighting source idea for the highlights later on today or this week.
-Josiah
