Painting Tissue Paper
    June 2016
Posted by David from PA on Thursday, October 6, 2016 3:27 PM
Don't know if this is the proper place to ask but does anyone know of a sure-fire way to paint the tissue covering on a balsa wood and tissue model?
David From PA
    July 2014
Posted by modelcrazy on Thursday, October 6, 2016 3:44 PM
You will need Dope (if they still make it) as a base first. then enamels will work just fine.
Edit:
Apperently Krylon Crystal Clear acrylic spray will work in it's place.
Steve
    June 2014
Posted by Tanker - Builder on Thursday, October 6, 2016 5:36 PM
Hi;
 If you cannot get " DOPE " there is a way to do it .Take " Spar " brand MARINE  Varnish or Shellac  , Thinned by fifty percent and you should be good to go .    When it's dry you can apply the color of choice . T.B.
    P.S. A secondary thought . When you build the kit they tell you , or used to , Wet with a spritz of water , when dry the covering will be tighter . Don't do this if you are going to put regular paint on it ! It will shrink so much it will split !
    Take craft clear in the spray rattle can , and apply a thin but thorough coat , Let dry and then paint to your heart's delight !
Posted by Don Stauffer on Friday, October 7, 2016 8:48 AM
Clear lacquer will also work, but many hobby shops do still carry clear dope.
    December 2006
Posted by crackers on Saturday, November 5, 2016 12:20 AM
Slikspan is like tissue but much stronger. Modelers of aircraft use silkspan to cover the airframes of their models.
Happy modeling  Crackers   Geeked
Anthony V. Santos
