hguc Powered GM work'n'progress
    October 2008
Posted by bsyamato on Wednesday, March 16, 2011 8:49 PM
mmh..
One of few exceptions between my zeon army
Ok this way i'll try to do no modding on this (only if indispensable) Super Angry
The mech come from 0083 oav .
The kit is pretty nice and have a great posability.
Unfortunately the parts division don't aid the painting for movable parts, so the only mods needes is focused on this.
Here the snapped and dusted kit (brought 2 or 3 years ago)
Photobucket
Starting the disassembling
Photobucket
Photobucket
The head is great:
Photobucket
On the arms the first obstacle, the elbow is fixed between foearms by a ilynder pin:
Photobucket
I semoved ll pins and blocks to allow a separate painting of differents pieces
Photobucket
the same elbow joint need some adjust, no pcb parts inside, the movement is done by the black abs plastic that rubs with other abs piece. i'll try to resolve this putting a little washes betwueen the pieces, this weekend..
At the next Black Eye
    April 2015
Posted by spadx111 on Thursday, March 17, 2011 2:09 PM
interesting build.
Ron
    October 2008
Posted by bsyamato on Thursday, March 17, 2011 6:18 PM
Thanx Ron
Little update, advantage of Italy 150 unifycation years celebrations... Cake
starting knee separation:
various pins prevent a good manipulation for painting, i'll build a pit to make pins unnecessary
Photobucket
placing various piece of plastic (tamiya glue used, CA glue will make a too rigid structure that can be break by legs movement)
Photobucket
Photobucket
Photobucket
lots of test fitting needed, the lower part is done, wating tomorrow for glue dry for finish.
The upper legs will be more difficult Sad .... soon updates
    January 2005
Posted by Watchmann on Thursday, March 17, 2011 6:23 PM
bsyamato
That's a great idea!  Thanks for the tip. :)
m@
    October 2008
Posted by bsyamato on Sunday, March 20, 2011 1:44 PM
Watchmann
 bsyamato:
m@
happy to know that it is useful Wink
and... after gluing the lower legs i can say that it's work good! (first time i use this tip).
The blocked knee joint it's a problem that have even others hguc i will build in future (hazel and rx-79g sure)
the results: the fitting is good
Photobucket
Photobucket
the chest is glued, ready for the total sanding as i used to do and panel lines engraving
Photobucket
head star painting, inner parts painted with humbrol 144
Photobucket
that's all for today..
winds of war beginned in libya... i'm about 400 km from there Huh?
    December 2005
Posted by dj898 on Tuesday, March 22, 2011 9:42 PM
with this type of kits you can use the c-joint modification for easy of seam line fix and painting.
the below is the parts breakdown of HGUC GM Light Armor Ver. Ka that I'm building...
hope this of some help.
people living in glass colonies shouldn't throw nuclear stones.
    October 2008
Posted by bsyamato on Thursday, March 24, 2011 7:06 PM
dj898
thanx dj898 but:
1) In this kit , the elbow parts  includes the joint for the shield, that provide to work good as pin for the whole rotation joint. Smile
2) I had forgotten the c-joint modification ... Crying
i can try it with the elbow middle parts.
    April 2008
Posted by smeagol the vile on Thursday, March 24, 2011 8:40 PM
Man, I really wana build a gundam kit but I dont wana deal with white, cable rings, or yellow... and that sort of cuts off most of them ugh
    October 2008
Posted by bsyamato on Friday, March 25, 2011 4:55 AM
Big Smile smeagol , this gm it's not perfect white, fortunately is light light light gray.
for cuts, it's just my mania, you can build and paint thr powered gm whitout these cuts, theres lots of masking solutions .
