Thanks guys. Now here's the thing that's crucial about the scene, I wanted the X-wing to be in "attack postion" , meaning wings unfolded, but that creates a problem with it sitting on the ground (landing gear under wings is at an angle). The X-wing I told you about from Diego solved this problem by putting the x-wing on jacks. Now I'm thinking, either I come up with some kind of garage-like base for the X-wing to sit on (like a lift) or I close the wings shut (which ruins the view on the cut away wing section) and let it sit on its landing gear. Or cut the lower wing off completely. Not sure yet. Logically speaking the X-wing was shut down or crashed so probably had no time to deploy it's landing gear? I am thinking the base should represent some kind of reverse engineering by the empire, taking the X-wing apart piece by piece (I still like the idea of some huge contruction type flood lights on tripods lighting the model). Oh and I cut the rebel pilot up in 3 pieces and glued him back together, he is either dead or seriously ill in this scene (he's leaning forward, head down) :) Or maybe I'll just leave him out. So much to decide! (fun though)
By the way I did some Star Wars models some years ago (work consisted mostly of integrating led lighting and paint job), you can find them here and here. A Finemolds Y-wing and a Revell Millennium Falcon. That's why with this X-wing I want to focus on the scene, the base and the custom parts instead of tedious fiberglass fiddling in cockpits.
I'll keep you guys posted, next up is an engine cut away and side of the body cut away (forward of the cockpit showing the missile launch tube exposed).
