Nino
Great work on the Horta. This is a really cool project.
One thing... You may want to review Spocks hands. His Thumb location seems wrong to my eye.
Live Long... etc.,
Nino.
I fixed Spock!
On to phase 2 of this subject, Kirk.
I would like a Kirk and Spock figure to go with momma Horta. The AMT Spock figure might be able to be modified, But there is no 1/2 Kirk figure.
Time to improvise. Night Owl makes a set of standing resin legs for the AMT Spock kit, It comes with a new arm and a hand. And JT Graphics makes a "Starfleet captain head" for the AMT kit, it comes with a PE communicator grill and rank decals and a command shirt badge.
The only problem is Nimoy was 6ft and Shatner is 5ft 10. He just looks too tall.
1/8 inch needs to be removed. The easiest, though not perfect, solution is to remove it from below the resin leg shirt line. It's a natural separation point.
Time to get out the Xacto razor saw!
The cut was not that bad, took about 30 min. The resin is very soft.
1/8 inch marked off.
and after sanding Kirk is "dry Stacked".
I'll glue the AMT kit styrene to the lower resin shirt, then glue that to the legs.
I'll probably use some sculpting putty to blend everything together.
Meanwhile I would like a crouching Spock to show the mind meld. The stock kit parts
are not crouching enough.
My 1st thought is to put the styrene legs in boiling water and re bend them. But that
might distort things too much.
My 2nd thought is to cut a small wedge out of the back of Spocks knees and cold bend them. Then re glue.
Does anyone have any thoughts? Better ideas?
I figure I need to bend them 20 degress or so.
The black legs are the DST crouching Spock legs from the Spock/Horta action figures,
that is where I need to get the kit legs.
Thanks
Mark
