T2 HK Tank
    December 2022
T2 HK Tank
Posted by Tcoat on Tuesday, April 4, 2023 9:27 AM
Ran into decal issues with my latest plane build so
 This is the 1/32 Hunter Killer tank from the Terminator 2 movie. As the "real" thing is described as 3 stories tall then even in 1/32 it is MASSIVE.
For anybody not familiar with Pegasus Hobbies kits the first thing that needs to be mentioned is that they are not styrene. The plastic they use is a heavy ABS. This means that some glues just won't work and they recommend Tamiya Extra Thin or Modelmaster liquid only. Of course you can also use super glues. I use the Tamiya and it works great.
Of course this subject is modeled after a movie prop and some of the parts seem a bit simplistic when you first look at the. For example the return wheels for the tracks have no sort of suspension to them but are simply little wheels on a stick. The wheels themselves have nice detail but that is about it. This of course is fie with me since once the tracks and side panels are on you won't notice anyway but anybody that really like to go to town could easily do more with these.
The track assemblies are huge of course but they fly together since there actually very few pieces.
The pieces there are you get to do 4 times
Pegasus uses a lot of slots and bevels in their design instead of locating pins. This does a good job of hiding most seams and is very strong but some of the bigger sections don't fit perfectly so there will be some filling and sanding. I understand that this can be hit and miss with the molds and was a lesser issue with the first release than this one (this is the 2021 rerelease)
The smaller assemblies fit really nice though
All sub assemblies done just working on seams
And for those that don't know how big these things are here we have a 1/35 Sherman lost in the middle.
    July 2015
Posted by MR TOM SCHRY on Tuesday, April 4, 2023 11:29 AM
Tcoat, I have this same kit in my stash so I'll be following along closely with your work.
tjs
TJS
    December 2022
Posted by Tcoat on Tuesday, April 4, 2023 12:16 PM
MR TOM SCHRY
tjs
Step1:
Buy glue.
    July 2015
Posted by MR TOM SCHRY on Tuesday, April 4, 2023 1:20 PM
That's a lot of Tamiya Extra-Thin cement.  What paint are you planning on using on the exterior?
tjs
TJS
    December 2022
Posted by Tcoat on Tuesday, April 4, 2023 1:28 PM
MR TOM SCHRY
tjs
Haven't decided yet. There are options.
Not that you get a really good look in normal lighting but in the first movie they appear to be just sort of a low gloss steel color.
But by T2 it appears that Skynet found a good detailing shop and they are bright and shiny almost chrome like.
They don't show up in the later movies but all the equipment that does runs between the two finishes so I don't think there is a "right" or "wrong" answer really
http://redirect.viglink.com/?key=71fe2139a887ad501313cd8cce3053c5&subId=3375912&u=https%3A//www.youtube.com/watch%3Fv%3DtJF9k1R0bPc
I sort of like the chrome look so will probably go with that and just dust up the lower parts.
    July 2015
Posted by MR TOM SCHRY on Tuesday, April 4, 2023 2:15 PM
That's the best thing of building SciFi, there's no wrong color.  I was thinking of using Tamiya's dull aluminum and some Uschi metallic powders.  Good luck with the build.
tjs
TJS
    December 2022
Posted by Tcoat on Tuesday, April 4, 2023 2:44 PM
MR TOM SCHRY
tjs
Will probably go about as shiny as the T800s in my diorama lttle shineir than the aerial HK.
https://cs.finescale.com/fsm/modeling_subjects/f/6/t/191890.aspx
Posted by Gamera on Tuesday, April 4, 2023 7:19 PM
Wow that's cool, I had no idea the thing was supposed to be this large.
Somehow I remember it being chrome, I guess I remember the second film better than the first. And the lighting conditions could really alter what colour the thing appeared as.
    December 2022
Posted by Tcoat on Wednesday, April 5, 2023 5:41 AM
Gamera
I always remembered it being chrome as well. Probably the same miniatures were used for both movies but they had a lot more cash for T2 so the lighting and effects were better and you could actually see the shine.
    October 2021
Posted by PhoenixG on Wednesday, April 19, 2023 11:30 AM
That HK is going to be massive when done.  Hope you have space for it on the shelf!
Loved the movies and I'm really interesested in seeing the build progress and end result.
On the Bench:
Bandai 1/72 Defender Destroid
    May 2011
Posted by Real G on Wednesday, April 19, 2023 12:48 PM
I'm not sure if I am remembering correctly, but I thought I had read somewhere that for T1, the HK tank was painted, but for T2 it was vac plated due to the much increased budget.
“Ya ya ya, unicorn papoi!”
    December 2022
Posted by Tcoat on Wednesday, April 19, 2023 1:34 PM
Real G
Wouldn't be surprised. I watched both movie openings several times for details and determined that T2 is certainly shinier. Could be lighting though. The good news is that you see small parts, at a distance or so briefly of each that I can detail pretty much however I want and it will be "right".
    December 2022
Posted by Tcoat on Wednesday, April 19, 2023 1:37 PM
PhoenixG
It is huge!
Since it will be going to my son's display space will be his issue.
Will probably sit bhind these guys:
    December 2022
Posted by Tcoat on Wednesday, April 19, 2023 1:55 PM
I have neglected my updates!
Base coat of Tamiya "chrome" silver on all surfaces. It took two full bottles! This will be the actual main colour for things such as the guns, arms and any un armoured parts. The "specs" for these things (you can find anything on the internet) say the body armour was high gloss titanium. I suppose that was too to help deflect the fire from a phased plasma rifle in the 40 watt range.
Hard to see in the picture but there are three different shades here. The Tamiya chrome, old Testers small bottle steel and silver. Then my usual overall wash of tinted Future (I use it on everything) finished off with a light wash of Citadel Nuln Oil shade. Normally I would do an overcoat of flat but this all needs to have at least some shine to it.
Couldn't decide what to do for the main body armour. Didn't want to go with some of the better know mettalizer paints since this is such a large area and they can be delicate at best. Had a little better than half a bottle of Modelmaster chrome and wasn't sure if enough but I got brave and went for it.
With judicious thinning and not getting carried away with the thickness I had plenty to cover where it was needed with enough left over for touchups if (well... WHEN) I need them.
It was exactly the finish I was after! Looks like "titanium" without being bumper chrome bright.
The gun support is the main body colour. Looks really good just plain.
But really comes to life once weathered!
Getting there.
The "head" is almost done.
    May 2011
Posted by Real G on Wednesday, April 19, 2023 2:28 PM
Tcoat
Real G
In the close-up shots where the soldiers are trying to place a mine in the HK tank's path, the tracks appear to be a darker metal color - weathered steel perhaps.
    December 2022
Posted by Tcoat on Wednesday, April 19, 2023 7:13 PM
Real G
Yep.
Tracks are Testers small bottle flat steel with a wash of Citadel Agrax Earthshade for some patina. Figured that even in the Skynet world of 2029 tank tracks are tank tracks.
Most of body is shiny silver (not bumpy like pictures make it look)with exposed equipment and some panels done in flat steel. Wanted variation but not massive differences.
Base
Steel with black wash
    December 2022
Posted by Tcoat on Friday, April 21, 2023 7:50 PM
DUDE!
Look
Behind
You
    July 2015
Posted by MR TOM SCHRY on Friday, April 21, 2023 11:27 PM
Tvost, this turned out great!  I think that the finish you went with is perfect.  Any plans to mount it on a base?
tjs
TJS
    December 2022
Posted by Tcoat on Saturday, April 22, 2023 12:07 AM
MR TOM SCHRY
tjs
I will be doing something of a base. Due to the shear size of it it won't be too elaborate though. Have some T-800s to go with it so just big enough to fit them in with a bit of ruins or something. Once I settle on the base's colour I will dust up the tracks and lower sections of the tank.
Posted by Rob Gronovius on Saturday, April 22, 2023 11:09 AM
This is so impressive. Yeah, I like the big stuff, but size is a limiting factor; no where to put it!
    December 2022
Posted by Tcoat on Saturday, April 22, 2023 12:46 PM
Rob Gronovius
This one is easy since it will be going to my son's house space will be his problem.
Posted by keavdog on Saturday, April 22, 2023 2:22 PM
Thanks,
John
Posted by Gamera on Monday, April 24, 2023 8:51 PM
WHOA Tcoat!!! That looks amazing!!!!
If I were Kyle Reese she'd give me nightmares!!!
    October 2021
Posted by PhoenixG on Friday, April 28, 2023 11:17 PM
It looks amazing.
Just the right amount of variation to keep it visually interesting without affecting the appearance of a single finish.  Beautiful job balancing everything out.
Two thumbs up!! YesYes Big Smile
On the Bench:
