hi jesse
,what i did to make a stand for my rc-ships(+80cm) simply take a bendable piece of wire(i used the ones for in the garden)and bend it around your lower hull to the hight you want your stand to come. then copy the 2 bends (fore and aft) to a piece of wood and cut it out. then messure your 2 wood stands to a plank where your ship is comming on (put a centreline first to line it up and glue the 2 upstands at 90° angle to the centreline) hope your can get any wise out of this
or else instaid of copy your bendable wire direct to your wood ,you can first copy it to cardboard so you can cut it a bit when it not fit right and the transfer it to wood.
