x-wing idea help needed
Posted by Anonymous on Tuesday, April 5, 2005 7:22 PM
i was going to tryr my hand at kit bashing with a couple of x-wings
i new to this so i was askin for any advice i could get for this idea i got from looking at twin p-51 mustang
i made this in photoshop to look at it betterEight Ball [8]
    August 2004
Posted by jdavidb on Tuesday, April 5, 2005 10:06 PM
You only need one R2 unit for the ship. I'd turn the non-R2 side's top kibble strips around backwards or slice it up & rearrange it to make it different from the other side. The rear kibble is hyperthrust equipment, so it should be the same on both halves. If you're planning on making linkage to operate the x-foils together, that's gonna be complicated with rails & gears inside and a bunch of work that no one will ever even see, so I'd work on making stiff joints for opening and closing both sides independently. I wouldn't do red marks on a non-fighting ship. Maybe brown, gray or black.
    May 2003
Posted by kylwell on Tuesday, April 5, 2005 10:10 PM
I'd space the fuselages apart a wee bit, maybe add two more engines.
Posted by Anonymous on Tuesday, April 5, 2005 10:20 PM
i was also thinking maybe putting another set of blasters there make it into a real fighter also i want the two r2s i side might get damaged or somethingQuestion [?]
thanks for the tips though guys im new to this and will need all the advice i can get
Posted by Anonymous on Tuesday, April 5, 2005 10:40 PM
Replace one of the R2's with a small laser turret, sort of like on the Y-wing. Interesting idea, haven't seen that before.
Posted by Woody on Tuesday, April 5, 2005 11:02 PM
Great idea! Just to keep everbody thinking, how about making it a heavy/assault fighter. Do away with the second cockpit on the other hull and make the remaining cockpit a two seater arranged like the snow speeder. In the place of the removed cockpit place an ION canon.As stated above just have one astro-mech. Make the back fuselage of the cannon side completely different with maybe a sheild generator toward the back and cooling equipment for the ION canon between that and the canon. You might think about an antenna like the dish on then Falcon mounted on a structure that ties the two back fuselages together. Very, very cool concept you've come up with! I hope you run with it.
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
Posted by Anonymous on Tuesday, April 5, 2005 11:14 PM
And then enter it in the SW contest over at Starship Modeler! Big Smile [:D]
Posted by Anonymous on Tuesday, April 5, 2005 11:27 PM
ill get to work putting it together in ps to get a good look at it
well heres some real quick work on the pc i couldnt find any good shots of the rear of the fighter
    August 2004
Posted by jdavidb on Wednesday, April 6, 2005 1:59 AM
For the wings to open/close, you could do away with moving hinges and go for a more simple (and reliable) slot and post system instead. One set of straight-out slots for closed and one set of fixed-angle slots for open with posts on the wings. There would be no range of motion to consider. This would mean you have to slide the wings out of the plane to change their position, but if you build it right, this is very sturdy and your X will always be perfect instead of rickety, floppy wings that flap all around. This is what I have done to car doors rather than struggle with pin hinge stuff. I'm really happy with the way everything is perfectly straight and sturdy. I used rectangle tube (common styrene stock) for the slots and the correct size rectangle rod to telescope inside the tubes. I've been making a lot of use of the miter box & saw, miter sander, L-square and protractor for this sort of scratchbuilding job.
Posted by Anonymous on Wednesday, April 6, 2005 8:17 AM
Definately put some space between the fuselages.Maybe you could make this bird into a counterpart to the TIE bomber.Some type of turret in place of a second cockpit would be extremely cool.
    August 2004
Posted by jdavidb on Wednesday, April 6, 2005 12:56 PM
yeah there's gotta be something on that 2nd fuselage or that whole half of the ship will seem pointless... a cockpit or major weapon or something has to be over there.
    May 2003
Posted by kylwell on Thursday, April 7, 2005 11:47 AM
'Nother set of engines, and, as somebody mentioned, maybe another set of cannon (for a total of 8, 4 on the wings and 4 in the middle).
Or, alternately, totaly remove the outboard engines and replace them with a set of high output engines mounted in the center section.
Then there's the concept of making the second hull some massive HWOD.
