X-82 Black Leader finished 26Jun
Posted by ssgkopp on Friday, May 5, 2006 6:11 PM
OK this is going to be a dual x-wing like the old P-82s from the korea war the dual mustangs
the middle section will have one or two engines plus a blaster and maybe extra proton launchers or maybe a bomb type thing
the second cockpit will get flaired over and given a small turret controlled by the seconded R2 unit
any suggestions are welcome
heres the start just the basic center section
did this about a yr ago in photoshop and finally got the kits at K-Bee toys for $7 a peice
Posted by Anonymous on Thursday, May 11, 2006 1:06 PM
Pretty cool idea.  Can't wait to see it completed.
Posted by ssgkopp on Saturday, May 13, 2006 4:51 PM
well got back from my trip and started on it
here are the pics slow and steady around sharp objects
will work on this side till almost done then knock out the other
thanks again for all the great ideas
k
Posted by Anonymous on Monday, May 15, 2006 10:08 AM
I have a similar idea with my old MPC/AMT Incom T-65; I need to reduce the overall length of the fuselage by reducing the nose and reshaping it and modifying the rear. I will install two sleek engine pods to the sides (similar layout to the Y-Wing). I've loved aircrafts with a center pod like the P-38 and OV-10 Bronco. All those panel lines will be filled smooth, and reestablish them by using a technical drawing pen after painting. I am doing some sketches before I start cutting.
Also, I need to take some test shots since I am having lighting problems (overexposure) on close subjects with my digital camera.
Happy Modeling,
Riƶ<*>
Semper Fi!
    September 2003
Posted by edklingon on Monday, May 15, 2006 5:25 PM
I liked a lot your ideia, keep going at this job. Sadly, I only have ONE X-Wing to spare in projects like this. Sadly...
Visit my website: http://paginas.terra.com.br/lazer/projectglue
Posted by ssgkopp on Saturday, May 20, 2006 9:30 PM
well did some more today i put a small fighter i did today next to it to show its size the little fighter uses the fusalage portion from the small mpc x-wing
still have to design some sort of bomb devive and put all six blasters on
    January 2003
Posted by cthulhu77 on Sunday, May 21, 2006 11:38 AM
Love it.  As a strategic light bomber, it would be perfect.  Any ideas for the type of agb/m you are going to use?
http://www.ewaldbros.com
Posted by Anonymous on Friday, June 2, 2006 4:39 PM
The Double-X wing... I thought of doing almost the excact thing your doing years ago but ran out of room, patience, time, etc... IOWs ...burned out...not long after that idea !.
I always thought this would be an excellent project, your doing a great job proving it was a good idea afterall ! Mine kept both cockpits one for pilot, one for bombedier.
Keep it going,  I'm building it along side you, if only in spirit!
I'm really looking forward to seeing the finish product.
Posted by ssgkopp on Saturday, June 10, 2006 9:46 PM
well i hit it with some primer in spots to find some bad spots and i see i have a few to fix
added the rear facing torpedo launcher on the bottom and extra sensors and intake and exhaust fans
also during flight testing it was found that the to fusealages would seperate slightly during tight turns and steep climbing so a brace and small manuver wings where added to the front thses also allow for a steeper dive pullout
well here you go any comments will only help
thx
k
Posted by ssgkopp on Saturday, June 24, 2006 5:08 PM
well started to paint and weather a bit
still workin oin the turret idea but decided to move ahead and maybe an idea would pop up
well herer are the pics
k
    November 2003
Posted by ilikespagetti on Saturday, June 24, 2006 8:38 PM
That looks really cool. I think I may try this but in the middle section put a B-Wing style engine. Keep up the good work.
I am a man, But I can change. If I have to....I guess...
Posted by ssgkopp on Sunday, June 25, 2006 11:04 AM
thx alot   its been a fun project
k
    September 2005
Posted by Fish-Head Aric on Monday, June 26, 2006 12:37 PM
This is a really cool bash, and I've enjoyed looking it over as it comes together.
I do have a question about it... What would be the "practicality" of such a craft as this in actual service?
~Aric Fisher aric_001@hotmail.com
Posted by ssgkopp on Monday, June 26, 2006 5:59 PM
better to have and not need
then to need and not have
i figured this would be a heavy (ier) fighter between th eXwing and the Y wing  has the same speed if not more then a x-wing but can punish as much as a Y wing can
almost done with this  got the turret done just have to lay down some paint  im going to tap it in place in case i find a better turret idea
glad you like it
Posted by ssgkopp on Monday, June 26, 2006 9:24 PM
well im calling it done i really dont like the turret but owell
dirtied it up real good
hope you like it
thx for all the help guys and gals
any fixes you see ill try to address
k
Posted by Anonymous on Friday, June 30, 2006 1:07 PM
Great looking job on the build.
