PL Refit, Advice needed *UPDATE*
Posted by Anonymous on Tuesday, December 19, 2006 5:31 PM
Hi again all,
   I'm finished with the subassemblies on my 1701-A, and am (almost) ready to start painting.
   Have a couple of questions first tho:
    1. What's the best way to mask all the little windows and glassy-bits
    2. Do I leave whatever masking I use on from Primer to finish coat, or does it need to be removed and reapplied at each stage? I'm concerned about removal once the paint has dried.
     And of course, any other tips/suggestions are greatly appreciated!!
                                 Thanks!!
*UPDATE* Disaster!!! As stated below, I used Testors Clear parts cement to mask the glassy-bits. Now I can't seem to get it off. I've tried peeling it off but it just wants to crack and chip. I do not recommend this technique.
   I'm headed over to the painting section and see if anybody has any tips for getting my windows and such cleaned off.
Posted by Anonymous on Wednesday, December 20, 2006 7:20 AM
Hi again,
   After using the search function, I'm going to try using Testors clear parts cement as a masking agent. I'll check back in and let ya know how it works out.
                                      Thanks!
    June 2004
Posted by Griffworks on Wednesday, December 20, 2006 10:42 AM
 Lanarian wrote:
Hi again all,
I've used Tamiya Liquid Mask on some of my models in the past, but have found it to be a bit hard to clean out of cracks/crevices.  Another alternative that I've seen folks use is Elmers Wood Glue.
                                 Thanks!!
Yes, leave it on thru every stage prior to the final clear (Dull?) coat until the paint has fully cured.  I recommend taking it off prior to your clear/dull coat.  I've not yet built a 1/350 PL Refit, but have never had problems with the above method on other kits I've built  in the past.
The greatest measure of a man is his children and what kind of people they are.
    November 2003
Posted by ilikespagetti on Tuesday, January 2, 2007 5:40 PM
Another thing that I have seen done is using a leather hole punching tool to make little circles of masking tape. maybe tedious but it works.
I am a man, But I can change. If I have to....I guess...
    November 2004
Posted by Chris_in_Japan on Wednesday, January 3, 2007 5:40 AM
Yeah patience is the key.. I rushed the first PL refit that I did, and although it turned out ok, it kinda showed.. This second one, I have stop started, stop started, but atleast I am not rushing it.. It will get done, but I definately will do the small thinf properly!.. So I say, do what feels right, but dont cut corners!
Chris
On the bench:
                          1/48 RAAF 3 Sqn F/A-18B
                          1/150 /1/160 N Scale Japanese Rail diorama.
Posted by Anonymous on Wednesday, January 3, 2007 6:25 AM
Hi all,
   Yep, I would definitely use masking tape next time (if I get a next time). I'm getting the paint and stuff off, but it's a real bear. adding some liquid (spit) seems to help loosen it quite a bit.
  Man, sometimes I really wish life had a rewind button.....
    January 2007
Posted by Zoloff Tinru on Friday, January 5, 2007 2:21 PM
  Microscale has a mask called  MICRO  MASK !Liquid masking medium.........                             Works Great!!!!
    December 2004
Posted by Hippy-Ed on Sunday, January 7, 2007 3:14 PM
Yep, but, I have been having troubles getting it off afterwards
If you lose your sense of humor, you've lost everything
    November 2004
Posted by Chris_in_Japan on Sunday, January 7, 2007 6:12 PM
Did you hold your tongue at 45 degrees like I said Ed?Tongue [:P]
Chris
On the bench:
    December 2004
Posted by Hippy-Ed on Sunday, January 7, 2007 8:01 PM
Chris
Yeup. Tried that.
    March 2004
Posted by Mikeym_us on Saturday, January 20, 2007 7:55 PM
why didn't you get the Aztec Dummy aztec masking set because it comes with window masks.(though I got version 2.0)
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
Posted by Anonymous on Sunday, January 21, 2007 7:07 AM
grrrrrr.. I KNEW someone was gonna ask me that...
   Honest answer? I did. But after applying all the aztecing, I just couldn't stomach the thought of applying it to all the windows too. I figured "There's just GOTTA be an easier way!!".
   So, valuable lesson learned.
   I'm currently taking a break from it. I've got several places where the paint has lifted (peeled?) either from the aztecing or from masking and miscellaneous other painting mishaps so I'm gonna let my frustration settle down a bit.
    December 2004
Posted by Hippy-Ed on Sunday, January 21, 2007 10:41 AM
a valuable lesson learned and this Monster is a learning experience.
Best thing to do when one gets flustered is to take a break from it. At least, that is what I do
    January 2007
Posted by Guido1081 on Sunday, January 21, 2007 5:19 PM
Heya,
  Does anyone use Parafilm anymore. That is what I used to use ( I am just getting back into building again). 10 years ago ( roughly ) it was the thing to use and abuse, not sure now.
Guido
    December 2004
Posted by Hippy-Ed on Sunday, January 21, 2007 7:31 PM
Hey Guido, Welcome to the forums & yes, some people still use parafilm. I just tried
some Frisket last night on my P-51B for the first time and it worked pretty good on the
open green house canopy. Might be good to use on this Monster Refit too!!Tongue [:P]
    March 2004
Posted by Mikeym_us on Sunday, January 21, 2007 7:43 PM
well as for me for the most part I am going to Aztec the saucer without the windows in place. Then assemble it later.
Posted by RonUSMC on Monday, January 22, 2007 1:48 AM
Use Micro Mask and then afterwards use a sharpened toothpick to peel it up.
http://finescalegallery.com Active Kits: 1/48 AM Avenger 1/35 Sd.Kfz 251 Ausf C
    December 2004
Posted by Hippy-Ed on Monday, January 22, 2007 11:53 AM
That sounds like a plan. at least ya wont have to worry about masking the windowsBig Smile [:D] I'll
probably try this since I've used the Micro Mask & have tried various methods to remove it. Tape, sharpened toothpick, Q-tip with alcohol, still had to revert to the back of a #11 blade to get it up thoSigh [sigh]
    March 2004
Posted by Mikeym_us on Monday, January 22, 2007 12:42 PM
did you try tweezers Ed? Because I use micro mask alot for clear parts and I just use tweezers to take it off with no problems.
    December 2004
Posted by Hippy-Ed on Monday, January 22, 2007 3:04 PM
Now once I get a corner up I'd grab it with the tweezers but, it's trying to get the corner upthat kills me!!Banged Head [banghead]and then it breaks after a little tug so, back to pickin' at it.  I've pretty much got it all off the Ent. D I'm working on tho
    March 2004
Posted by Mikeym_us on Monday, January 22, 2007 6:38 PM
now if only they can make a unbreakable wooden toothpick. Thats my only problem with toothpicks now with the tweezers I gently use the edge to pick the edge up then slowly pull the sheet of micromask off of the window. Now as for the Refit I am not sure if I should start it before or after I start on the Reliant.
    December 2004
Posted by Hippy-Ed on Monday, January 22, 2007 6:41 PM
Banged Head [banghead] do both!!Whistling [:-^]
    March 2004
Posted by Mikeym_us on Monday, January 22, 2007 7:16 PM
I've got time to build both but not the space since my workspace is also my bedroom. And I think it is going to get interesting when I wire up the 30+ grain of wheat bulbs that I have (though I think I might only need 10)
here are pics of my 35 Grain of Wheat bulbs.
http://img.photobucket.com/albums/v332/Mikeym_us/100_0212.jpg
http://img.photobucket.com/albums/v332/Mikeym_us/100_0211.jpg
http://img.photobucket.com/albums/v332/Mikeym_us/100_0210.jpg
http://img.photobucket.com/albums/v332/Mikeym_us/100_0209.jpg
    December 2004
Posted by Hippy-Ed on Monday, January 22, 2007 8:02 PM
Space,... the Final Frontier... LoL... Big problem ther and here tooSigh [sigh]
    December 2004
Posted by Hippy-Ed on Monday, January 22, 2007 11:44 PM
LoL I don't think I could even consider trying to light up my Enterprises!!Shock [:O]
That just looks too dang small & confusing for meBanged Head [banghead]
    March 2004
Posted by Mikeym_us on Tuesday, January 23, 2007 12:01 AM
Ed I definitely think I'll need a bigger transformer unless I can find a way for a 14 volt LED to work with a 9 or 12 volt transformer. But there are 8 green 2 red and 25 clear LED's and they are 14 volts. And I do have some bulbs I took off of my AMT Star Destroyer with fiber optics that work with 9 volts.
    November 2004
Posted by Chris_in_Japan on Wednesday, January 24, 2007 4:03 AM
Cant say I have been game enough to light anything either.. The Bandai models are about as far as I have gotten with lighting!Approve [^]
Cant wait to see once you have it all worked out though!..
Chris
On the bench:
    December 2004
Posted by Hippy-Ed on Wednesday, January 24, 2007 11:31 AM
LoL... all greek to me!! sounds like you've got your work cut out for ya tho.
WB Chris!!
    November 2003
Posted by ilikespagetti on Wednesday, January 24, 2007 5:06 PM
Yeah I'm with Ed here, I'm having a hard enough time trying to motivate myself to wire two jumbo LED's in my T-800 Endoskull.
    December 2004
Posted by Hippy-Ed on Wednesday, January 24, 2007 11:30 PM
LoL you got more guts than I (or no brains) as I know I don't posess the skills nor patience to attempt a wiring job like thatSigh [sigh]
