OK
It has been a while, but now I have plenty of pics to share.
What was done:
The model is mounted , as you can see below. The rear pedestal is a 3mm shorter than the front one, hence the model sits lower by the stern. I am not sure you can see it in the image below. Initial mounting has been a disaster: I had overdone the bow-stern difference, so I had to ramedy the problem by lifting the keel up from the rear pedestal by about 4 mm and sticking a styrene rod in there. You can't see it really, and overall I am happy with the way it is mounted.
Underwater hull is, as you can see, painted as well.
The bulkheads are in place, and so are the decks (masts are just hangin in there, they are still being worked on)
Now, the decks for some reason come out really yellow ini the picture, but this is not the case, in reality they are of a much paler colour - now idea why is this colour changed by my camera.
The gun carriages are installed in the waist, and can be seen in the image above. Once rigged, I will snap a better picture.
I had installed the gun port ropes, anchor cables, and channels:
Why did I have to drill the holes for the port ropes in the gunwhale, is beyond me, at this point. In any case, that's how it will be :(
Paiinting is still going on. Gold decorations are very time consuming - each fler-de-lys has three layers of gold on it - initial coat, darker shade in the middle, and a highlight. The most annoying had proven to be the gallery windows, however:
I am trying to get the gilted framing, and it's still a work in progress. Couple of shots of the stern:
Some windows still need a bit of work, though.
I am used to painting 52mm model soldiers, and a level of detail I am accustomed to there is really holding me back now :)
Lastly, below is the main fighting top. Out of the box it had came out without ANY slots on the sides, where the ratlines would be going through - I had to cut them out. Am I correct? Having the top solid (other than the openning in the middle for the mast) leaves no way of attaching ratlines, and it is not clear how there were supposed to be entered :)
