Another rigging question
    May 2010
Posted by salvine on Thursday, November 10, 2011 3:46 PM
Been reading quite a bit on this. My question is do I use clear or black nylon mono filament for my 1/350 Burke.
Posted by Don Stauffer on Friday, November 11, 2011 9:05 AM
I would not use black for 1:350.  Both black and white threads stand out and create a high contrast- that is, they appear larger than they really are.  You need a medium grey.  Hard to find in a monofilament.  I'd use the clear.  Consider trying to color it. I have successfully colored the clear mono thread with magic markers.  Grey is a hard marker color to find, however.  I have used a medium brown with some success on modern 350 scale ships.  In 1:700 there is no question, use the clear.  But in 1:350 it is a more difficult question.
    March 2007
Posted by bondoman on Friday, November 11, 2011 10:52 AM
http://www.jsflyfishing.com/cgi-bin/item/TW-030020-0000/63500/UNI-Products-Caenis-Thread.html
It's black, but so thin it's not really easy to see. It scales about 3/4" thick at 1/350, which is as close as I can find to the real thing
Posted by Don Stauffer on Saturday, November 12, 2011 8:58 AM
bondoman
Digital calipers these days are very cheap.  The monofilament I buy is 7 mil in diameter.  Still, at jet black, it would tend to be more visible.  Even at 350 scale it should be barely visible.  You might try a touch of brown magic marker, or even see what happens if you put some white marker on it. If it turns white, that is no good- white looks as bad as pure black.  But if the white tints it gray, that would be a good result.
    May 2010
Posted by salvine on Monday, November 14, 2011 7:36 PM
So I got the rigging for the front of the mast but I'm having a tough time with detail for the cables that go to the rear from the lower yard arm, Any pics of this. Most shots on the web don't have enough detail.
