Minicraft 1/350 Titanic old version
    January 2012
Posted by iceberg on Monday, January 9, 2012 8:42 AM
I have attempted to bend the water pipes that attach to # 3 funnel. To accurize them they should be shortened about 5 mm. Repeated efforts to bend them have resulted in breaking them so they are  useless.
If anyone has been successful in accurizing each set of pipes and then bending them to fit onto the funnel I would sure appreciate any tips. I am frustrated with my attempts.   Thanks,Iceberg
Posted by Ray Marotta on Monday, January 9, 2012 12:40 PM
You might try using a soldering pen for a spot application of heat to bend the plastic.  Or, try replacing the plastic "water pipes" with copper wire of the appropriate diameter...
Good Luck
Ray
    January 2012
Posted by JollyRoger on Monday, January 9, 2012 6:27 PM
You might want to check out the TRMA.  A gentleman by the name of Art Braunschweiger did just that on his 1/350 Minicraft kit and his steam pipes look outstanding (along with the rest of his model).  You can see his progress on the funnels here.
EDIT:  Here is the pipe bending post.
