Actual built size of the 96 Constitution ?
    March 2012
Posted by David_K on Monday, April 16, 2012 6:58 PM
Hi everyone-
So I kinda looked around the forum for an answer, but I wonder if I could just ask outright:
Who knows the Actual size of the Revell 1/96 Constitution when built?
Different vendors seem to have varying sizes (around 3 feet) advertised.....my thing is, I have a glass display case that is 33" wide and 29.5" high....I was hoping I could fit the completed ship inside the case, and not have to buy another one for it...if it will fit, I may buy the kit this weekend, and shelf it until after the Summer...
So again, does anyone have it, or the actual measurements of it as completed?  Seems like 33" is so close, that I hope I can get it to fit!!
Thanks!  I know the *connie* gets a lot of attention here, and it might be a tired subject for some of you!
David
        _~
     _~ )_)_~
     )_))_))_)
     _!__!__!_
     (_D_P_K_)
Current Project:  Imai/ERTL Spanish Galleon #2
Recently Finished: Revell 1/96 Cutty Sark
Next Up:  ???
    July 2008
Posted by jeffpez on Monday, April 16, 2012 7:27 PM
Mine isn't totally done but it's 33 7/8 long. I only have the foremast up and it's about 27 tall without any stand or base under it so I'd say your case is too small in both dimensions.
    March 2010
Posted by Jerome Morris on Tuesday, April 17, 2012 8:06 AM
Boy what timing!  David, Yesterday a Constitution was dropped off to be put into a case.
 The actual finished dimensions are exactly 35 3/8" long, jib boom to end of the spanker.
Height sitting the little plastic base is 25 1/2" tall
width is 13" at the main yard measured to include the stun sail booms which happen to stick out beyond the main by about an inch port and starboard.
I don't believe your case will work, Sorry. The case I'm building will be 40" long , 27" tall and 16" wide.
    March 2012
Posted by David_K on Tuesday, April 17, 2012 8:53 AM
Thanks for the help, anyway....I hope to build a kit that big one day, but man!.... the cost of a display case is more intimidating than the build!!  :)
Looks like I'm out of luck for the Connie...too bad, because Amazon has it on sale for $55....I think there's only a couple left at that price.
Guess I'll just keep working on my Wasa, and hope the right kit comes along once I'm done!
Thanks again!
David
        _~
     _~ )_)_~
     )_))_))_)
     _!__!__!_
     (_D_P_K_)
Next Up:  ???
    December 2010
Posted by 1943Mike on Wednesday, April 18, 2012 11:00 AM
David,
Here's a thread from last year on this forum about the subject of your query:
/forums/p/140598/1478680.aspx#1478680
1943Mike
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    October 2010
Posted by bambam on Tuesday, April 24, 2012 8:52 AM
Dear David,
With all respect, wy don't you put the kit in an acrilic box? The kit is big and with the wood base will become very heavy, bot with acrilic sould be  a bit slight and less dangerous. I have bouth Constitution and Victory builted in an acrilic redoma at the wall and some times for cleaning I have to put down and it would be very dificult if it was inside of a glass.
BAMBAM
    March 2012
Posted by David_K on Tuesday, April 24, 2012 9:36 AM
Bambam-
Yes, acrylic is a good material for display cases (especially Larger ones!)....and that may be my choice if I end up going with a kit that big....my original question was just so I could find out if the case I already have would accommodate it.  Turns out, even in acrylic, the cost of material for a case to fit the 1/96 connie would be approximately 300 $US....for those kind of duckets, I'll probably keep my eyes out for a kit that I really, really like....the connie's great, but I think I might even go into something wooden....like I said, if I have to spend hundreds to get a case, I want to display a kit that means a lot to me....
Thanks!
David
        _~
     _~ )_)_~
     )_))_))_)
     _!__!__!_
     (_D_P_K_)
Next Up:  ???
