Hey all,
I thought I'd start this thread in the hopes that I could field questions out to you guys and and hopefully get some expert advice. I've been following the forums for a little while and only just recently got back into model making.
I used to build model airplanes when I was a kid, but now as an adult I have a hankering to get back into it. My wife bought me the Revell 1/570 RMS Titanic kit and I loved every minute of its construction.
I'm way into subs and so I decided that my next project would be the 1/72 Type IXC U-boat from Revell. I know it's a bit of a step up, but I'm very comfortable building things and learning new techniques. And with your help, I expect to learn a lot.
So here's where I'm at...
I bought the Eduard PE sets, the periscope set, and the propellors set. I'm unsure if I should dremel out the flood holes, mainly because I don't really want to build the pressure hull inside. I DID dremel out the flood holes around the bow torpedo tubes.
Here are a few pics:
I just loosely taped together the hole just to envision where I'm headed. It's not ready to put together yet, obviously.
I started by cutting out the flood valves and putting in the PE set.
I then worked on the bow torpedo section. I went ahead and drilled out the flood holes here but I'm not sure if I'm going to put anything inside to block the view straight across to the other side (aside from the torpedo assembly).
I'm opening the torpedo doors on the starboard side but keeping the port side doors closed. That way I can show the model two different ways.
I applied the PE floodhole sections but have not drilled them out. My plan is/was to pre shade the flood holes black and keep them dark through the rest of the painting. I don't really want to build a pressure hull. But I'm open to suggestions.
My main questions right now are:
1. Should I drill out any or all of the flood holes if I'm not planning on building a pressure hull?
2. Should I prime the bow torpedo assembly before installing it in the hull?
Any and all feedback is welcomed!
Thanks!
Señor
