1/72 Type IXC U-Boat Build Log
    March 2014
Posted by Señormodeler on Wednesday, October 8, 2014 9:30 PM
Thank, Hokey! Sure thing.
I used the Eduard PE for this kit (there are 3 sets). I considered Oto's brass deck but it wasn't ready in time, so I just used the kit deck. I also used a brass kit that has the screws, the UZO, the captsans and few other items.
I primed the kit with Tamiya Fine Primer. Then I preshaded all the rivet lines and panel lines. I used reversed pre-shading for below the waterline. After that I painted the sub with LifeColor paints. They have a Kriegsmarine set of paints that colors that I wanted to use.
I had a little trouble with the LifeColor paints, probably due to my inexperience. I had trouble figuring out how much to thin it. It would clog in my AB very easily. So I ended up thinning it quite a bit and layering on a lot of thin coats.
I then sealed it up with Future floor polish and started weathering it. I used Gamblin artist oils and odorless turpentine for all the washes and filters.  I started with several dark washes of black and brown. I would then put down a dull cote to seal it. I used dot filtering above waterline. Below the waterline I applied some light grey filters to fade the base paint.
I was able to get some splotchy effects by diluting some white oil paint with lighter fluid and splattering that on the hull below the water line. The lighter fluid drys very quickly and leaves behind an irregularly shaped faded mark. I basically continued to apply different oil paints as I saw fit, and then started adding specific rust streaking on the conning tower and upper hull.
For the deck I used nato black and then painted areas of earth brown to make it look like the carbilinium had worn away.
After all that I did just a little bit of pastel weathering here and there. To age the screws, I soaked them in vinegar and salt for a few days.
That's about it. I started it in April and finished last week (October 3). I learned a lot. It was my first attempt at weathering something major.
Hope that helps!
    February 2011
Posted by Hokey on Thursday, October 9, 2014 8:26 AM
Thanks Senor!  Can you tell me what the name/brand of the screw, etc. kits too please?
    March 2014
Posted by Señormodeler on Thursday, October 9, 2014 8:35 AM
Found it:
www.tehnoart.eu/u9-fittings-set-1.html
It includes a PE radar assembly.
    December 2010
Posted by 1943Mike on Thursday, October 9, 2014 9:53 AM
Señor,
This looks to me to be an excellent submarine build. I'm so very impressed. Thanks for posting your WIP since it has added to my knowledge and my appreciation of this hobby.
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    March 2014
Posted by Señormodeler on Thursday, October 9, 2014 12:11 PM
Thanks, Mike. I appreciate that.
    February 2011
Posted by Hokey on Friday, October 17, 2014 11:14 AM
Señormodeler
Found it:
Did you also get a machined periscope set?
I am emailing Oto about the brass deck too.
UPDATE: I got his reply. It reads:
"hello here is my work for type IXC.
http://www.modelforum.cz/viewtopic.php?f=176&t=80880
eduard doing a few deck covers. It is not sufficient, so I designed the entire deck"
Can you look at his work and give me your thoughts on his 2 kits? I have the 3 Eduard sets already so I guess there would be some waste with one or the other?
    March 2014
Posted by Señormodeler on Friday, October 17, 2014 11:21 AM
Yes I did get periscopes. And gun barrels.
Schatton-Modellbau:
Type IX periscopes (72168)
Type IX AA gun barrels (72169)
    February 2011
Posted by Hokey on Friday, October 17, 2014 12:33 PM
Señormodeler
In reading other info at UBoat.net the paint schemes seem to pretty much stay with a light grey and dark grey approach. Many quoted sources referring to Model Master RLM 63 and RLM 72 (light and dark grey) for upper and lower hull.
Those paints are gloss acrylics so I'm guessing that when I finish the build, spraying with a FLAT clear would solve that problem? Maybe you sprayed flat finish as well?
    March 2014
Posted by Señormodeler on Friday, October 17, 2014 1:11 PM
Hokey,
For the color scheme I pretty much followed Glenn Cauley's lead on his U-505 build:
www.travel-net.com/.../U505
He's done a lot of research and has specific information about the exact colors. LifeColor paints offer a package of paints that included the specific greys that I wanted. There's a lot of variation to the grey (it has a bit of green in it) and I wanted to try to get it really accurate.
The LifeColor paints have a matte finish but I sealed them with Multi Surface floor polish, which is gloss, and applied a a few washes first. Then I sealed that with dullcoat and started layering it with filters and streaking.
    February 2011
Posted by Hokey on Friday, October 17, 2014 4:14 PM
I did note that before and maybe its just the color in his photo on the web but it has no green/blue tint to it that I can see. Its more the basic grays described on UBoat.net.   Bottom line, I'm sure both (and other slight variations) are totally acceptable to the masses!
When I look at the actual boat in the museum, the bottom paint does have a bit of green/blue More in photos with the blue floodlights!) to it but I also note the upper paint is quite a bit lighter like the Hellgrau 50 color.
Basically I'm totally confused!!! LOL...
And......I need to get off my butt - quit investigating everything - and get to building!
    March 2014
Posted by Señormodeler on Friday, October 17, 2014 7:54 PM
Agreed. Whatever shades of grey you choose will be totally fine. Jus a question of how insane you wanna get. You may want to check out this site if you haven't already. There is a off on there all about the kriegsmarine u-boat colors.
And get building!
Posted by Bish on Saturday, October 18, 2014 12:41 PM
That is one nice looking boat. Its been a real joy following this build and I have certainly learned a lot. I will be book markings this for future reference. I really like the finish and all the streaking and other weathering. That's exactly the look I hope to get.
A huge well done and thank you.
    March 2014
Posted by Señormodeler on Saturday, October 18, 2014 4:31 PM
Thanks, Bish! That means a lot. You've been very helpful throughout the process. I'm working with someone to build a display case and I'm still doing a little work on the stand. I'll post some final pictures once I get those things done.
In the meantime I'm focusing on my fine molds 1/72 millennium falcon. 900 pieces!!
    February 2011
Posted by Hokey on Saturday, October 18, 2014 6:48 PM
Señormodeler
And get building!
Thanks for the "nudge"!!!  You refer to "You may want to check out this site if you haven't already" but I don't see a link there? Did I miss something Senor?
    March 2014
Posted by Señormodeler on Sunday, October 19, 2014 8:35 AM
Sorry honey. Here's the site I was talking about:
http://amp.rokket.biz
    March 2014
Posted by Señormodeler on Sunday, October 19, 2014 8:46 AM
Sorry *HOKEY!
    February 2011
Posted by Hokey on Sunday, October 19, 2014 5:18 PM
LOL OK "honey"!
