Primer Poll
    February 2011
Primer Poll
Posted by Hokey on Thursday, April 24, 2014 2:39 PM
Can you ship builders please share:
(1) Do you rattle can or air brush primer?
(2) Do you decant rattle cans to air brush?
(3) Regardless of method, what brands do you like best in either category?
Thanks!
    July 2010
Posted by docidle on Friday, April 25, 2014 2:21 AM
Hokey,
I use Tamiya extra fine primer from a rattle can on my models.  I have not decanted the primer.... Yet.... I haven't had any issues so far.
Steve
Posted by Don Stauffer on Friday, April 25, 2014 9:12 AM
I use Krylon primer. Rattle can.  I use the standard gray primer except where the major finish color is either white or yellow. Krylon offers a white primer which I use in those cases.
I learned about Krylon primer from the old Usenet newsgroup rec.models.scale for those of you who remember newsgroups.
    February 2011
Posted by Hokey on Friday, April 25, 2014 9:44 AM
Thx. Any others?
    March 2005
Posted by philo426 on Friday, April 25, 2014 10:20 AM
I use Tamiya neutral gray acrylic cut with 90% isopropyl alcohol through my airbrush.(Paasche Vl)Works great every time.
    August 2005
Posted by EdGrune on Friday, April 25, 2014 10:33 AM
I use Ace Hardware's red primer. Large economy sized rattle can. Good coverage, shows flaws and sands well. Less expensive than the ones with the model manufacturer's logo on the can.
The red is also an excellent color for USN hull red.
Shop for alternatives from other markets. The products there are often more economical than items offered specifically modelers
    September 2006
Posted by the Baron on Friday, April 25, 2014 11:50 AM
I have used automotive primer, usually WalMart's store brand, until recently.  That  was mostly for cost concerns--it covered decently, and a can lasted pretty long, for the low price.  I would use light or medium grey, or rust red, depending on the subject.  However, I have recently bought a can of Tamiya primer, and I may start using it exclusively for all scale models, despite the price.  I like the fine grain of the surface, very smooth but with good "tooth", and not to thick.  That was a problem with automotive primers--they can go on thick, if you're not careful.  And the Tamiya primer covered pretty well, too, so I think the little can will last over more projects than I though.
Another problem with the automotive primer is that I've had a couple cans where the can got clogged--not the nozzle itself, but at the point where the nozzle gets inserted.  It's happened with over half the paint left, and I've had to pitch those cans.  That eliminated the advantage of the low price.
I haven't used the airbrush to apply primer.  I do want to test using the finer grades of Mr Surfacer as a primer, though, and that would be applied with the airbrush.
    August 2005
Posted by Tracy White on Friday, April 25, 2014 12:52 PM
Tamiya rattle cans and some "Games Workshop" rattle cans I still have from when Tamiya paints had import problems into the US. Sometimes Mr. Surfacer.
Tracy White Researcher@Large
Posted by Tojo72 on Friday, April 25, 2014 3:10 PM
I use Mr Surfacer 1200 or Tamiya Extra Fine,both directly from the rattlecan
fox
    January 2007
Posted by fox on Friday, April 25, 2014 3:55 PM
Dupli-Color Sandable primer, Grey. Rattlecan.
Jim Captain
 Main WIP:
    February 2011
Posted by Hokey on Friday, April 25, 2014 4:18 PM
Thx everybody. Seems no one air brushes it!
    September 2012
Posted by GMorrison on Friday, April 25, 2014 4:28 PM
I use Krylon flat white in the rattler.
I recently had a bad experience with Humbrol enamel over Tamiya primer.
    July 2004
Posted by stikpusher on Friday, April 25, 2014 4:46 PM
1) I prefer to airbrush on primer due to far superior control.
2) I have yet to decant any rattle can stuff, but would like to do so one of these days
3) I have used and prefer (in order):1. Humbrol primer from the tin; 2. Mr. Surfacer ; 3. Tamiya Liquid Surface Primer. All have worked well for me.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Don Stauffer on Saturday, April 26, 2014 9:26 AM
the Baron
One thing to watch with modern spray cans-  in addition to cleaning the nozzle, by inverting can and discharging for a few seconds, you must replace the cap as soon as possible.  Nowadays the caps seem to have the section that covers the nozzle seal airtight. I have had several cans go bad when I neglected to replace the cap promptly.
