Looking for tips on build sequence for painting measure 32 camo
    September 2007
Posted by the Paterfamilias on Tuesday, May 27, 2014 6:26 PM
Hi folks.  I am starting the Trumpy 1/350 USS North Carolina, and will be incorporating the Tom's PE set.  I want to apply the measure 32 camo scheme.  I am uncertain whether it will be better to try to paint this angular camo scheme on the sub-assemblies before applying the photo-etch bits... and then either brush paint the PE bits after they are attached, or try to paint the PE before attaching and hope the patterns match up?
Or, is it better to apply all PE parts to sub-assemblies first and then try to mask around them to paint the camo?  This approach seems destined to result in broken parts and ineffective masking... but I'm really not sure.
I'd appreciate any tips & advice from folks who have painted one of these types of schemes on a ship with lots of PE details.
    September 2012
Posted by GMorrison on Tuesday, May 27, 2014 6:35 PM
The answer is, it's not easy and you need to take your time. It's hard edged at least, so you can use a brush.
You are right- masking and spraying installed railings isnt going to work. Other single colored subassemblies are easier.
If you spray what you can, and then install the rest and brush, you should be fine. I find that ship models are pretty much brush jobs except the bigger areas.
Does Gator make a mask set?
Edit: Gator does. That'll really help.
Posted by Don Stauffer on Wednesday, May 28, 2014 8:58 AM
I generally paint the PE on the plate before removing the parts. I figure out the dominant color and then paint the plate that color.  For remaining pieces, I paint them one of two ways. If the piece is small I brush paint it (on top of prime and first color coat).  Only the larger remaining pieces see the airbrush.  With small pieces, I can paint them after assembly with a small brush, so those small pieces I find I have painted the wrong color can be corrected after gluing in place.  I never mask a PE piece after gluing it to a model.  I am afraid glue will not stick to the pe piece that well.  Even with primer, paint adhesion to either brass or stainless is not that great.
    September 2007
Posted by the Paterfamilias on Wednesday, May 28, 2014 9:56 AM
Thank you for the replies!  Don: That's really helpful advice on painting some of the PE before installation.  GMorrison: Great tip on Gator masks... I've inquired to Kenny about ordering a set.
