On the Bench: Trumperter Tsesarevich on deck Glencoe USS Oregon
So very nice!
Looks really good. Makes me want to start my U.S.S. New York BB-34. You did a very nice job on her.
Hector Berlioz
Nice finish! How is the kit's detail?
Very good work Bill. Glad to see this one cross the finish line.
Eric
Very nice!
What are those mounting stanions? Were they supplied in the kit? They almost look like some sort of ammo cartridge.
I bought the stantions in the lamp fittings section at Ace Hardware. They are threaded on the inside.
Bill
Very beautiful! Could you please explain how you worked with the railings? I am still having fits with the railings on my 1/700 Kirishima.
warshipguy Very beautiful! Could you please explain how you worked with the railings? I am still having fits with the railings on my 1/700 Kirishima. Bill
Baron,
First, simply cutting them from the manufacturer's framework is an exercise in frustration given that there is no clear demarcation between rails. Second, correctly shaping them around the barbattes when they are difficult to see is maddening. It was easier in 1/350 scale. But, this is one cross we bear when modeling 1/700!
at this scale pe rails are very difficult. I use white glue, and I lay a thin line of the glue along the edge of the ship where the rail needs to go. I let the glue dry a bit then place the cut section of rail on the glued section. to go around obstacles I struggle a lot and lose many pieces of p/e railing. Good luck
