hull numbers
SM2
    December 2012
hull numbers
Posted by SM2 on Monday, April 18, 2016 3:35 PM
How do you guys tone down white hull number decals on a darker ship hull?  I've got a navy blue hull with white numbers, and they're way too bright.  Will coats of clear darken them up some?  What do you do to weather them in?  Thanks,
Jim
Posted by Don Stauffer on Tuesday, April 19, 2016 8:46 AM
If you have an airbrush, you can overcoat with the hull color.  A double-action airbrush is best, but you can do it on a single-action brush, just dial the flow way down.  This technique also dulls down the semi-matt finish on many decals.
    June 2014
Posted by Tanker - Builder on Friday, April 22, 2016 3:43 PM
Hi;
     Usually when I am weathering . I do this .I will add all those goodies then I take a wash of The hull color and I mean a wash .The thinner looks just slightly contaminated, shoot from about four inches at low pressure 5 # or so. Wipe gently in the appropriate direction ( Down and slightly Aft) and let it dry .You shouldn't notice anything other than a blending ( slightly ) in the coloration .
SM2
    December 2012
Posted by SM2 on Friday, April 22, 2016 11:38 PM
Thanks, guys, for the ideas.  I don't have an airbrush, though.  I did try drybrushing with the basic hull color, and that gave me the general effect I needed.  Thanks again,
Jim
    June 2014
Posted by Tanker - Builder on Saturday, April 23, 2016 11:15 AM
S.M. 2;
   Good going , then .that's how I started .Go for it and when you're satisfied that's what counts !   T.B.
