Ships
    January 2012
Ships
Posted by fright on Thursday, September 22, 2016 9:12 AM
I know that technically this is not considered a ship but, here is my 1st model build since my junior high school days. I inherited Revell's 1/72 Gato submarine unopened kit from my father-in-law who passed away. After sitting in my closet for about 4 years, I decided to build this kit in his honor. I was not aware about PE parts, so none was used. I did use CMK crew to add to the sail on this boat. I noticed there were no exhaust holes so I drilled two holes in the apropriate location on upper hull. I also used a .011 guitar string for the railings instead of the thread provided. Once she was almost completed, I made the decision to try my hand at 'weathering' as well. I used a combination of graphite (exhaust holes), oil pastels (rust), and watercolors to help create salt water. I regret not keeping a record of the build but I did take periodic photos while working on this boat. Time spent: approx. 1 year on and off.  http://s1075.photobucket.com/user/fright52/library/Gato%20Submarine?sort=3&page=1
Robert O
    August 2014
Posted by goldhammer on Thursday, September 22, 2016 9:18 AM
From PB, I've found the easiest way to post pics here is to go to the upper left of the pic you want, click on the "share", a box will appear to the right with 4 options.  Click "copy URL", click on that and it will flash a yellow "copied".
Come over here and use the regular reply box (not the quick reply), type in your text, hit enter to get a fresh line.  In the icons box above you will see on the lower left a box with scissors and two other icons, click on the right hand one and the URL will appear. Repeat for further pics.
Posted by Don Stauffer on Thursday, September 22, 2016 9:21 AM
That is what the results would be for inserting each picture.
You do have to do the work of copy/paste each image, but I think it is worth it rather than require reader to copy and paste.
    June 2014
Posted by Tanker - Builder on Thursday, September 22, 2016 9:47 AM
Hi , Again !
 You posted somewhere else on this site and I saw the Boat .Yes , although a sub , she should be in the ships forum . By the way .Did you know you forgot the " Tompion " or Plug for the gun barrel ? Thank You   T.B.
    June 2014
Posted by Tanker - Builder on Thursday, September 22, 2016 9:49 AM
Hey !
 With this explanation it's beginning to make sense to me  . Keep hammering , I'll get it yet .  T.B.
    July 2014
Posted by modelcrazy on Thursday, September 22, 2016 10:07 AM
That's an outstanding looking job FrightYes Great use of the materials to do the weathering and rust.
Steve
    December 2010
Posted by 1943Mike on Thursday, September 22, 2016 10:56 AM
What Goldhammer and Don have said and done just takes a little practice .. you'll get the hang of it soon.
Nice job!
Here are several more of your images:
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    September 2005
Posted by warshipguy on Thursday, September 22, 2016 11:19 AM
fright,
What do you mean by "technically not a ship"?  As any good submariner knows, there are only two kinds of ships; submarines and targets".
Bill Morrison
    January 2012
Posted by fright on Friday, September 23, 2016 9:07 AM
!943Mike - Wow! Many thanks for posting thses photos! I'm like a cro-magnon when it comes to computers. Thanks for thowing me a bone LOL.Confused
Robert
Robert O
Posted by Tojo72 on Friday, September 23, 2016 9:31 AM
A very impressive build
    January 2012
Posted by fright on Friday, September 23, 2016 1:02 PM
Thanks goes out to everyone for the likes and vote of confidence. Big Smile
Robert O
    February 2011
Posted by Hokey on Friday, September 23, 2016 2:34 PM
Please tell me what this hole is for!
    August 2014
Posted by goldhammer on Friday, September 23, 2016 2:47 PM
For a line to the dock when tying up dockside, also for a towline to the bollard on the forward deck.  If you look close at the photo, you can see a line coming out of the bullnose and going hard off to starboard.
    February 2011
Posted by Hokey on Friday, September 23, 2016 3:28 PM
goldhammer
Got it! Thx.
    December 2010
Posted by 1943Mike on Friday, September 23, 2016 5:18 PM
Hector Berlioz
    August 2014
Posted by goldhammer on Friday, September 23, 2016 5:40 PM
Just curious as to the hull number you selected?  Only reason is that the Gato's ended at hull number 284, and the Balao's started at hull number 285.  They were built on the same overall specs, the major differences being a thicker pressure hull out of HS steel, and different scope shears on the Balao's.  No biggie, but noticable for someone familiar with both classes.
I hope I do as well on my build when the time comes to put her on the building ways.  Nicely done!
Posted by CapnMac82 on Saturday, September 24, 2016 12:06 AM
There are some excellent items on SS-291 USS Crevalle here:  http://www.navsource.org/archives/08/08291.htm   in case of interes
The trapezoidal box on top of the 40mm is a sheetmetal cover over the feed tray.  These were typically painted the same as the rest of the mount.
Y=The numbers on the side of the conning tower (it's not a sail until free-flooding fairing are installed a la Guppies) just don't look quite right for some reason.
Everything else is spot on and a spectacular build.
    January 2012
Posted by fright on Saturday, September 24, 2016 12:15 PM
Goldhammer - You are correct on classes of boats. As my first build, I used this number to represent one of my father-in-law's boats the he served on. I added the lookouts because he was on night watch when a large wave broke over the the sail, breaking his nose on  the railing. I know there are some discrepencies on my model, but not having any experience in fabrication of plastics, I built this kit as is. I am really grateful that I learned a bit of these ships history and of it's crew. :) There are so many talented modelers in here and I look forward to gaining more skills in modeling future builds. I'm hooked on modeling now. I've since tried my hand on Trumpeter's SS John Brown and Lindberg's Cap'n Kidd Pirate ship. I realized that 1/350 scale is too small for my vision, even with magnifier! Cheers and I enjoy everybodys feedback.
Robert O
    January 2012
Posted by fright on Saturday, September 24, 2016 12:32 PM
1943Mike - thank you for taking the time tp post all of this information! I'll try this on another model to share in here. Everyone has been very helpful and kind with their comments. Looking through the gallery, there are so many talented modelers in here. Hats off to all of you!
Robert O
    August 2014
Posted by goldhammer on Saturday, September 24, 2016 12:40 PM
fright
I thought that might be the case.  Not to worry, I am finishing up a 1/350 Gato that was to be Wahoo (SS238) and it is now going to represent USS Chub (SS329), another Balao.  Going to a friend who's father served on her at the end of the war, to go with his flag from his memorial service.  Nice to see another build memorializing someone who served back then.
    September 2005
Posted by warshipguy on Saturday, September 24, 2016 1:53 PM
Excellent build, especially for a novice! But, yes, submarines are ships that are affectionately referred to as "boats" by their crews.
Bill
    December 2010
Posted by 1943Mike on Saturday, September 24, 2016 5:59 PM
Robert,
All I did was to add some visual information to the succinct and correct procedure that goldhammer has written above. I tend to be a visual learner so I assume (often incorrectly) that most people's learning curve will become shallower with pictures.
Anyway, you're welcome.
I sure hope you post more of the 1/350 ships you've done! What you've shown us here is very fine indeed.
Hector Berlioz
    June 2014
Posted by Tanker - Builder on Friday, September 30, 2016 11:30 AM
Hi;
 There is one other use .I have seen three tied to a Bouy ( Mooring Bouy ) and the first one in had the line and chain for the bouy passing through the port . T.B.
    January 2012
Posted by fright on Saturday, October 1, 2016 2:28 PM
LOL Well said Bill Morrison! My father-in-law use to alway point that out. I have one of his tshirts with that very same logo on it. :)
Robert O
    September 2012
Posted by GMorrison on Saturday, October 1, 2016 3:38 PM
First, a fine model.
Second, a nice tribute. I built a P-61 and a Beaufighter In that vein.
As for Balao vs Gato, first time aboard Pampanito, I proudly stated to the volunteer that I was a ship guy and knew she was a Gato.
    January 2012
Posted by fright on Sunday, October 2, 2016 9:49 AM
CapnMac82 - "Ay aye, Capn!" lol I used the decals that came with the model. Not sure if the scale of decal is correct. I learned later on about the 'silvering' effect when using decals. At this point, I will probably try using Dull Spray to see if it helps. Thanks and cheers!
Robert O
    January 2012
Posted by fright on Sunday, October 2, 2016 10:02 AM
GMorrison - thank you for your comments. It is nice to be able to tie a memory to a model indeed. I just recently got the chance to visit the USS DRUM while in Mobile AL and even had a chance to meet Tom Bowser, a long-time volunteer who helps in restoring her, and learned he also had spent some time on the CREVALLE. Small world and a small ship! Smile
Robert O
    January 2012
Posted by fright on Tuesday, November 8, 2016 2:04 PM
Goldhammer - what a nice way to honor your friend's father. ^ 5 to you!
Robert O
