2 items: Revell USS Kearsarge on sale for FREE: best glue to fix a snapped plastic bowsprit.
    August 2006
Posted by Robert on Sunday, August 27, 2017 3:27 AM
1. I bought a Revell Civil War USS Kearsarge, kit 05603, on eBay,and it is complete except two right hull halves and no left one. Not the seller's fault but Revell's. eBay gave me a full refund; I wrote to Revell and they said the left hull half is no longer available, so I just want to get the entire thing off my hands to anyone who wants it, no charge.
2. After a year's work finishing a large Revell Cutty Sark, all rigging complete, the jib boom snapped off just above the dolphin striker. What's the best glue to ensure this doesn't happen again? I've taken down all the bowsprit rigging and shudder to think of re-doing it then another disaster happening.
Posted by gregbale on Sunday, August 27, 2017 5:53 AM
Robert
CA (aka 'super glue'), epoxy or even solvent-type cement should work fine, but the key is to drill out and reinforce the join: a section of paper clip, small metal rod or nail, anything that will add strength and keep its rigidity. Without that reinforcement, any glue will just fail again.
Good luck!
Greg
George Lewis:
    September 2005
Posted by warshipguy on Sunday, August 27, 2017 6:48 AM
Robert,
I have an extra port side hull half if you would like.  Don't give that kit away!  That extra hull half came from a kit that was destroyed in a flood; I kept it around in case someone like you could use it.  It is yours for the asking.
Bill Morrison
    August 2006
Posted by Robert on Sunday, August 27, 2017 6:57 AM
warshipguy
Robert,
Bill Morrison
 Bill I can't thank you enough. I'm not sure how to communicate with people off site, so as to send you my address.
Posted by CapnMac82 on Sunday, August 27, 2017 6:20 PM
As below, putting a brass rod or similr thing in the dolphin striker is what is needed; the glue is then slightly irrevelant.
Ditto the joint where the jibbom passes through the doubling on the bowsprit.  Or, the other oft-busted poit, the very end of the jibbom proper where it narrows down.
That latter sometimes better replaced entire using a bit of brass rod of the correct diameter, and drilled into the end of the jibboom.
As to the hull, it looks, above, a if serendipity serves.
Revell never really made enough of the Kearsarge kits, so they command ridiculous prices for that rarity.
The dirty little secret is that the CSS Atlanta hull is actually a more accurate Kersarge hull (in much the same way the Thermopplye hull is really a Cutty Sark).  But, that may be just my own bias  about Revell's commitment to accuracy in those days.
    September 2012
Posted by GMorrison on Sunday, August 27, 2017 8:23 PM
I'm thinking you mean CSS Alabama. Must have water in your keyboard. And, I'm thinking you mean that the hull is more accurately like Kearsarge.
That CSS ship model is fairly much garbage. Most obvious problem is that the actual ship had a really pretty rake to her masts, which the Kearsarge/ cloned Alabama does not.
But that Kearsarge model you have (half of) is well worth the build.
    September 2012
Posted by GMorrison on Sunday, August 27, 2017 8:27 PM
As far as part two, since you've done the wise thing and struck the rigging, replace the whole spar. I'd think a turned birch dowel would be strong enough. Unlike something like a schooner, she doesn't need a lot of strain on her jibstays, almost slack if you can manage it.
    February 2016
Posted by gene1 on Thursday, August 31, 2017 2:43 PM
Bill, you are the most helpful, thoughful person on this forum. Thank you for all you have done for me.
  I guess everyone fixes things with a piece of brass wire drilled into both ends of a brokn spar or landing gear. I keep a lot of brass wire of all sizes for doing everything. I use ACC glue after I have drilled both holes & glue one side & check that the wire is the right length & glue the other side over it. Stronger than new.
    August 2014
Posted by goldhammer on Thursday, August 31, 2017 3:11 PM
Robert
warshipguy
Robert,
Bill Morrison
Robert - if you click on Bill's avatar, it will take you to his profile and on the right center is "private message".  Click that and you can send him your address, only he will get it.
    September 2005
Posted by warshipguy on Friday, September 1, 2017 11:41 AM
Gene,
Thank you for your kind comment! I appreciate it very much.
Bill
    September 2005
Posted by warshipguy on Friday, September 1, 2017 11:55 AM
GM,
There are other problems with the Alabama as well.  Gun positions are incorrect, the deck layout is incorrect, the kit uses incorrect cannons, the hull shape is wrong, the rake of the masts is wrong . . .
ScaleDecks has produced a wood deck for this kit that is far more correct.  By fixing everything except for the hull shape the Revell kit can be made into a sort-of reasonable depiction of the ship in a larger scale than 1/96.  But it is doable.
Bill
Posted by CapnMac82 on Friday, September 1, 2017 9:48 PM
hurrhurr
Now, I'm wondering what I typed that autocorrect made it into Atlanta . . .
    February 2006
Posted by Wilbur Wright on Sunday, September 3, 2017 8:24 PM
Robert,  you may try to use a hardwood dowel and taper it.  I have a 1/96 Cutty Sark which I put back in the box ready for the completed masts to be glued on and rigging started.  I need to solve this issue as well to complete this model in the future. The jib boom is way too flexible.
I put that on the back burner because if I do rig it, I want a display case first.
You could try brass rod inside and CA, but I don't know how  much tension it will handle on a repaired joint.   I think John Tilley had a post on here about this topic if you look for it.
I built a Revell  1/96th CSS Alabama several years ago as I got it cheap.  It was the first sailing  ship I have built as an adult and it was a lot of fun, however I found out later about the innacuracies.
If  you google "CSS Alabama (revell)  fine scale", I think it is the first photo that comes up.  The large photos are gone because of photobucket.
In any case good luck with the repair. Let us know what you used, and how it worked.
