1964 USS Maddox - call for help
    May 2009
Posted by Pawel on Wednesday, April 11, 2018 4:13 PM
Hello!
Recently a paper model of the USS Mannert L. Abele came out:
1:200 Answer USS Mannert L. Abele
It's a Sumner Class destroyer, sunk in 1945. Seeing it gave me an idea to rework this model to build the USS Maddox as seen in 1964. I've already got some info as to changes that would be necessary here, like differences in armament. But I'm writing this post to ask you for help - can you provide me with more details on how this rework would have to look like? What would be the differences between a 1945 Sumner and a 1964 non-FRAM Sumner?
Thanks in advance and have a nice day
Paweł
www.vietnam.net.pl
    August 2005
Posted by EdGrune on Thursday, April 12, 2018 7:10 AM
The bridge house on a '64 Maddox is enlarged and enclosed,  perhaps the largest change.  Change the pole mast to a tripod mast and change out the radar suite.
Add ESM antennas to the aft stack.  Change the radar on the MK37 to a MK25 dish.
Navsource.org has some decent photos
You mention the armament, so you are aware of the 3"/70 replacements for the 40mm BOFORS.  Tubs will need to be adjusted for each of these mounts.   They are a bit larger than the 40 mm mounts.  There is a director structure for the aft twin 3"/70 that you will need to add.
Loose all the 20mm guns and gun galleries.
As lost, the Abele had a quint torpedo bank between the stacks.  Loose that.
The Maddox had just one depth charge track on the starboard side.   Loose the port one.
And you may also be aware - re-print all of the kit hull pieced which are done in camouflage into Haze Gray, with a large shaded hull number.
    May 2009
Posted by Pawel on Thursday, April 12, 2018 3:32 PM
Hello Ed!
Thanks a lot for the info! Your list looks good to me. I was aware of most of the points you mention, but my problem is an absolute lack of drawings here. Like the bridge - I see the photos of how it is supposed to look like, but I'm not sure if I can get it right in the model without any drawings.
"Losing" the gun galleries - I'm nos so sure how this is supposed to look like either.
And I have also heard the Maddox got some 50 cal MG mounts, I don't know where those would be neither.
I was thinking about re-printing the parts vs. painting the built model gray, but since many details are just printed on the parts, re-drawing and re-printing them seems lithe the thing to do.
So if anybody has any drawings of the Maddox or a similar ship I'd like to ask for help here.
Paweł
www.vietnam.net.pl
    September 2012
Posted by GMorrison on Thursday, April 12, 2018 4:44 PM
Interesting project, Pawel. I think you know your vietnam history, this is a pretty significant part of it.
I hope you do a WIP.
Posted by CapnMac82 on Thursday, April 12, 2018 9:41 PM
Pawel
Good news there--that's just a heavy steel post just inboard of the railing on (I think) the 03 level about even with the mast.
MGs are only mounted for actual Battle Stations (or, if in a theater of potential conflict, at General quarters, but under an oilcloth cover; so, it would look like a blob on a stick).
I want to remember that there's a page on the net which has the General Arrangement for the 3"/50cal Mk 33, which gives minimum tub dimensions for around those mounts.
Decent photos: http://www.seaforces.org/wpnsys/SURFACE/Mk-33-gun.htm
Another link:  http://www.navweaps.com/Weapons/WNUS_3-50_mk27-33-34.php
Ok, video of the guns in action:
Here's what I could find on the Mk 52 Director:  https://www.ussslater.org/tour/decks/flyingbr/gun-dir-hut/director.html
Found a reference stating the Mk 52 needs a 6' working radius.
    May 2009
Posted by Pawel on Friday, April 13, 2018 3:53 PM
Hello!
Thanks a lot for your comments!
GMorrison - if I decide to tackle this one (when I have enough reference) - I will definitely do a WIP. I need too much help here not to do so!
Capn' - thanks a lot for your input. I have taken a look at those links, pretty interesting stuff. I didn't know this AA system before, looks like it was pretty capable. I have also already found those babies offered in 1/200 at Shapeways - that's a good sign!
The info about the MGs and the director is also very interesting.
Now I have to dig some more to find at least some drawings for the bridge.
Thanks again for your great help and have a nice day
Paweł
www.vietnam.net.pl
Posted by CapnMac82 on Saturday, April 14, 2018 12:37 AM
For plans, you might consider Floating Drudock (http://www.floatingdrydock.com/TFW2.htm) Which might help with the bridge fit (you might have to research Hull numbers to decide which plans to get).  USS J.P.Kennedy might be useful (I want to remember she has Mk33 mounts aboad, up there in Fall River, Mass.)
