Paravanes.
Designed to haul a sweep wire out away from the forefoot of a ship. The sweep wire would collect the lines on moored mines and pass them to a cutter at or near the paravane. The mine would float to the surface out near the end of the sweep, where it was meant to be dealt with by small arms fire (shot until sunk).
Paravanes became de rigeur after the Washingto Naval Treaties. The compromises in ship size, but also quantities of ships in classes made it necessary to be able to self-sweep.
All USN combatant vessels cruiser-sized or larger carried them.
During the 30s, it was considered a matter of naval prowess to be able to stream paravanes, with careers hanging in the balance in getting the things over the side and back again.
Actual wartime use appears to be nearly nonexistant.
One for the lack of tactical reason to steam through minefields.
But, mostly, becasue, during the 30s, everybody added non-moored influence mines. Paravane has no effect on magnetic or acoustic mines. And capital (cruiser or larger) ships were the specific sorts of targets influence mines were meant to go after.
Add in that many of the wartime officers all too well rememmbered the angst and rigamarole around peacetime paravane streaming and eschewed it for just that reason.
But, since they were issued to the ship, you couldn't really leave them ashore.
