Returning modeler - first build in progress (Heller Corsair 1/150)
    August 2018
Posted by JurS on Tuesday, September 4, 2018 12:25 PM
Heya all,
As I said in my introduction post, I am a returning modeler, now retired and hoping to have a go again at making some models like I used to do in the dim and distant past. I have noticed that the standards have gone up a long way now, far better than what I used to turn out back then, so I am a bit hesitant to show my work. Still, the best way to improve is to just get on with it, do one's best and take criticism on board!
So here we go. My first kit is a small ship by Heller, what they call the 'Corsair'. Apparently this is based on an existing model of a so called Tartane, a small ship from the Mediterranean. I think I spot some Arabic influences in the shape of the stern?
This is the box art:
This is a cheap and simple beginners kit at scale 1/150, so good practice material. I am not aiming at perfect accuracy but more at an overal impression. I am making some changes as I go along to (hopefully) improve on the basc kit a little bit.
Here are the hull halves after initial painting. I don't have an airbrush so this is brush work, before any detailing and weathering.
The bare hull, with some weathering. I use oil washes over a base coat of acrylic. I would like to show the deck planking a bit more clearly but am not sure how to do that - they are raised, not inscribed, so a wash doesn't really work very well. Perhaps I should have put on a black base coat, then a wood coloured coat followed by some very gentle sanding to bring out the planks?
A bit further on, the hull is now almost complete with details. In the kit the inside of the bulwarks are plain, I have tried to improve on that by adding an impression of the frames using plastic card. I also drilled a hole for the anchor line in the deck and the bulwark, and added some more belaying points for the rigging.
The guns are still loose, they are tiny and I am not sure I am up to rigging them in. As they say, when in doubt, leave it out?
Next up is stepping the masts and then some rigging. The rigging diagram in the kit is way too simple and I want to go a bit beyond that. I don't like the plastic sails and will leave them off, which simplifies the rigging of course. I bought some small wooden blocks, there isn't a lot in the kit. I'm not actually sure about the shrouds, as far as I can tell these small vessels didn't have deadeyes and lanyards, perhaps someone in the know can enlighten me?
Jur
    August 2018
Posted by JurS on Tuesday, September 4, 2018 12:27 PM
Hmm, I am not sure what is up with the picture tags? Instead of just linking to the pictures all of my text acts as a link to Postimage? What am I doing wrong? I use the 'Hotlink for Forums' link from Postimage.
    August 2018
Posted by Flint on Tuesday, September 4, 2018 5:30 PM
That's looking great so far! I don't use an airbrush either. A decent set of watercolour brushes do me just fine. I used some careful scraping with a blunt scalpel to weather each individual plank of wood on the Black Pearl. Maybe try that?
I can see your pictures ok, but if I click on them, it sends me to the PostImage home page.
Posted by keavdog on Tuesday, September 4, 2018 5:43 PM
Welcome back to the hobby.  Nice start on a cool subject.
Thanks,
John
    September 2012
Posted by GMorrison on Tuesday, September 4, 2018 5:45 PM
Welcome! That model looks good so far.
    July 2013
Posted by steve5 on Wednesday, September 5, 2018 12:32 AM
your model look's great jurs . welcome back .
    August 2018
Posted by JurS on Wednesday, September 5, 2018 2:19 AM
Thanks for the welcome, guys. I have been reading through the forum and you guys make some really impressive models. They are a true inspiration! I don't know why Postimage does this thing with underlining my text. I found that you can right-click a picture and select 'View Image' to show it in a larger format.
Posted by keavdog on Wednesday, September 5, 2018 2:29 AM
Cool - right clicking works.  Why did the older ships paint the gunwales red?
Thanks,
John
    March 2018
Posted by Luvspinball on Wednesday, September 5, 2018 10:18 AM
Looking good so far, jurs.
When you add the link from postimage, use the "direct link" to copy here.  Never had an issue that way.
Bob
Bob Frysztak
Luvspinball
Current builds:  Revell 1/96 USS Constitution with extensive scratch building
    September 2012
Posted by GMorrison on Wednesday, September 5, 2018 10:23 AM
keavdog
Because red paint was cheap.
Posted by Don Stauffer on Wednesday, September 5, 2018 10:46 AM
Looking good!
I agree that rigging the guns can be a challenge if you are not practiced. If it has been awhile since I have rigged a ship, I find I need a bit of time till I get my *** back. Even when I come up to speed again, I cannot do much rigging at a single setting.  It is tension-producing, so take frequent breaks. If it is a complicated larger ship I put it on the shelf for awhile while I build a simpler model.  However, your craft does not have the rigging of a full three master, so you may not need to take a longer hiatus.  However, with rigged ships the best advice is, take frequent breaks and don't rush things.  Also, there are specialized tools for rigging that are not part of the tool set of people who only do other genres of models.  Good tweezers are a must, and little hooks and forks are very handy.
    August 2018
Posted by JurS on Wednesday, September 5, 2018 1:11 PM
By the way I tried the 'direct link' from Postimage, but that then only shows a link, not a picture. Weird stuff.
    July 2013
Posted by steve5 on Wednesday, September 5, 2018 2:26 PM
you only left click on direct image , and copy should show up .
    August 2018
Posted by JurS on Wednesday, September 5, 2018 2:37 PM
Yes, it does that, but I think it is nicer to show the pictures in the thread itself. Oh well, it is not a big issue.
    April 2016
Posted by Staale S on Thursday, September 6, 2018 9:29 AM
JurS
I also did some research on the rigging  and found quite a few illustrations of this type of vessel (mostly dhows, but I think there is a clear relation with the tartane), they all show a system where the shrouds are rigged with ordinary blocks, like this:
Yeah, that is pretty much standard for lateen-rigged Mediterranean vessels. They didn't use the otherwise standard shrouds-and-deadeyes arrangement seen in square rigs. They need to be able to slack off the lee shrouds and tighten up the weather ones every time they go about, because the lateen yard is carried outside the shrouds and not on the inside. (I strongly suspect that the yard on such a rig is not actually called a "yard" and that the shrouds are not actually called "shrouds", but it is all a bit too specialized for my tired little brain!)
You see a rather similar overhanging stern structure in xebecs as well, by the way.
    August 2018
Posted by JurS on Friday, September 14, 2018 8:51 AM
Progress is slow, but there is no hurry really. I've added the main mast and bowsprit, and put on the shrouds and the main yard halyard. Looking at the pictures I now think that the blocks at the top of the shrouds are overscale. I need to consider if I want to redo all that, including the shrouds, or chalk it up to experience and move on...
    December 2010
Posted by 1943Mike on Saturday, September 15, 2018 9:51 PM
JurS,
When you have left clicked (copied) the image in Postimage, do you then use the "insert/edit" icon just above the FineScale Post Body window? (The icon that looks like a rectangle with a mountain and the sun inside - just to the right of the hot link icon).
I hope you don't mind but I copied one of the above images, went to the Testing Forum and posted your image. When I click on the image it appears as it should in Postimage.
See here:
http://cs.finescale.com/fsm/feedback_help_and_testing/f/43/t/180003.aspx
BTW, excellent work so far.
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    August 2018
Posted by JurS on Sunday, September 16, 2018 2:40 AM
I use the 'share' icon on Postimage and then directly paste the link here in my draft post. This causes all subsequent text in my post to become a link as well, looks like a bug somewhere.
I don't understand your method, what do you mean by 'left clicked (copy)' the image in Postimage?
I have decided I will cut the shrouds and replace the lot with smaller blocks. I just know that these overscale blocks will bother me forever if I don't do that...
Posted by Don Stauffer on Sunday, September 16, 2018 6:41 AM
In postimage I select the thumbnail of the photo I want, to get the full size photo.  Then I left click on the large image.  I select, from the drop down menu, copy image location.
Then, after clicking on the image symbol in my post, the cursor should be in the source window.  I just use control-v, or copy, to paste that image location.  Then click OK.
    August 2018
Posted by JurS on Sunday, September 16, 2018 8:52 AM
Thanks Don, let me try that now:
I think that worked!
I had a look at replacing those blocks, but the lines are glued around the masthead and I don't think I could get them off without damaging the mast, so I left them. One to chalk up to inexperience!
To be honest after adding some more rigging, as in the picture above, it isn't too noticeable perhaps.
Still more to do, but I find this rigging very tiring on the eyes so I only do little bits at a time.
    December 2010
Posted by 1943Mike on Sunday, September 16, 2018 1:09 PM
JurS,
Sorry for the confusion.
I do essentially what Don said.
PS. Anytime I see the word "share" in cyberspace, I avoid it.
Hector Berlioz
    February 2012
Posted by Liegghio on Sunday, September 16, 2018 2:30 PM
I have also read that on large warships the gun decks were painted entirely in red so that when the ship took hits in combat the gore splattered around wouldn’t freak out the surviving gun crews. I don’t if that’s true or not, it seems to me seeing your mates get splattered would be bad enough that painting everything red wouldn’t make much of a difference. Barns were always painted red because the paint was cheaper so I’ll vote for that explanation as well.
Posted by Don Stauffer on Monday, September 17, 2018 8:30 AM
Liegghio
Not only was red oxide paint cheap, it weathered very well.
    August 2018
Posted by JurS on Tuesday, September 18, 2018 5:20 AM
Well I think I am finished with her, for now. She is only a small model, and I am reasonably happy with how she turned out, my first model after many years.
It is a nice kit, the biggest issue is that the masts and spars are very thin and will bend and break easily. This poses some issues for taut rigging. The rigging instructions are useless, the box art is much better and certainly points the way, that plus some research has given me a fair idea of what goes where. Obviously I left off the sails, the vacuum ones look terrible and I am not yet in the game of making my own.
My next project is again a ship, but something rather different. I may post a thread when I get a bit further into it.
Jur
Posted by Don Stauffer on Tuesday, September 18, 2018 8:51 AM
Beautiful results!
    July 2013
Posted by steve5 on Tuesday, September 18, 2018 2:24 PM
excellent job , why don't you start at the start with your next thread mate , I'm sure we would all enjoy it.
    August 2018
Posted by JurS on Tuesday, September 18, 2018 2:42 PM
Allright, I'll do that.
Here is a taster:
    July 2013
Posted by steve5 on Wednesday, September 19, 2018 12:22 AM
looking good , I was looking at this model , but it was a little too pricey for me , will be following , on your other thread .
