New Jersey life rafts
Posted by Anonymous on Monday, August 8, 2005 10:14 PM
What should the color of the life rafts be? The photo etch is showing the fronts are black with a haze gray back. Is this correct?
    January 2003
Posted by Jeff Herne on Monday, August 8, 2005 11:06 PM
The life rafts should match whatever the color on the bulkhead is...if the bulkhead is haze gray, then the rafts are haze gray...if a demarcation line runs directly through a life raft, then that line carries over onto the raft.
Jeff
Posted by Anonymous on Tuesday, August 9, 2005 7:08 AM
Thanks Jeff, That is how I had things until I looked at the instruction sheet from Gold Metal.
    March 2005
Posted by mfsob on Tuesday, August 9, 2005 10:10 AM
Jeff is right if everything was painted at the same time. I have seen photos of the rafts on camouflaged ships all being one gray color regardless of where they are on the ship, because they were probably all serviced/stocked/repainted at the same time, on a day when the bosun was looking for make work for the deck gang. So maybe either way is correct.
    March 2004
Posted by Mikeym_us on Tuesday, August 9, 2005 12:36 PM
what scale New Jersey are you working on?
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
Posted by Anonymous on Tuesday, August 9, 2005 3:41 PM
I'm sure you are talking about the modernized New Jersey, in which case the instructions on the GMM sheet are correct. You actually aren't painting the life rafts, there is a tarp placed over them, which is black/very dark grey in real life.
Posted by Lufbery on Wednesday, August 10, 2005 8:10 AM
Are the life rafts the canisters stuck to the sides of modern ships? I've seen a lot of them lately in FSM with the Nimitz review and the 1/96 scale Missouri in this month's FSM.
Regards,
-Drew
Build what you like; like what you build.
