What to do with this old kit?
Posted by Anonymous on Tuesday, November 1, 2005 1:37 PM
A while back while visiting my grandparents my dad came across an old model kit of his. It is an old Renwal Blueprint Models 1/200 USS George Washington nuclear sub. Now, I'm not sure what to do with this thing. The instructions are still there, a bit yellowed, but still perfectly readable. The kit was partially assembled and painted, but the cement was so old and brittle that I found it very easy to take the assembled pieces apart without damaging them. This made it a lot easier to catalog what pieces were there and which were missing. As it turns out, about half the parts are MIA. Fortunately, all the large components (like decks and bulkheads) are still there. It's the little things that are missing. Tiny lockers, tables, some torpedoes, some missile tubes, and other small pieces are missing (I still can't believe they had a piece of meat to hang in the kitchen in the parts list!). In short, a lot of scratchbuilding is going to be needed to salvage this thing. My question is, is it worth doing? I put it to you, the more experienced ship modelers, what I should do with this model. Should I work it to completion when my skills are up to the task? Should I use it as spare/scrap plastic for paint practice? Should I just let it sit by as a "museum" piece?
    March 2004
Posted by subfixer on Tuesday, November 1, 2005 2:12 PM
Considering that the interior is based on what might be called "artistic license" and by no means accurate at all, the best thing would probably to finish the hull and exterior fittings and paint the whole thing black. It would be better than letting it go to waste.
I'm from the government and I'm here to help.
    January 2003
Posted by cthulhu77 on Tuesday, November 1, 2005 3:39 PM
It would be a perfect place to enhance your scratchbuilding skills... go crazy, and put in a disco floor !
greg
http://www.ewaldbros.com
    December 2004
Posted by Hippy-Ed on Tuesday, November 1, 2005 4:00 PM
Gee... that's a dooziey!![:0] Sounds like Kit-Bashing tyme!!Tongue [:P] Throw in a bowling alley while yer at itWink [;)]
If you lose your sense of humor, you've lost everything
    July 2013
Posted by DURR on Wednesday, November 2, 2005 9:54 PM
it is such an old kit that few people have seen it so build it as it was meant to be you will amaze your friends
and us too post pics as you go
