Windows on the Island?
    June 2005
Posted by MontanaCowboy on Tuesday, November 8, 2005 9:14 PM
Just looking through my Trumpeter 1/350 Nimitz CVN 68, and it appears no windows are provided. Kind of wierd, I thought, considering the two PE sets for it come with wipers. What's up with that? Also, where can I get some windows or at least some clear styrene. Any tips for this kit? I will be buying some more planes for the airwing, as well as those two PE sets to replace the safety nets as well as radars, Etc. Thanks!
"You know, Life is like a Rollercoaster. Sometimes you just die unexpectedly." No wait, that's not it.
    August 2005
Posted by EdGrune on Wednesday, November 9, 2005 10:39 AM
Clear stryrene is available from Evergreen.   Check the rotating display rack at the LHS.
Clear plastic is also available by salvaging it from the tops & bottoms of clear plastic salad bar containers from the local grocery store.
You may also want to look at Micro CrystalKleer.  This is a white-glue like substance which dries clear.  Put some on the tip of a toothpick & rub around the inside of a window opening.  Surface tension holds a film of the material in the opening.  When it dries it is clear.   IIRC, CrystalKleer can also be tinted with food coloring (i.e. to make the glass green).
    June 2005
Posted by MontanaCowboy on Wednesday, November 9, 2005 3:37 PM
Hmm, I don't recal seeing clear evergreen sheets at the LHS. I'll check again. I actually blew a bubble with future once!
    March 2004
Posted by Mikeym_us on Thursday, November 10, 2005 3:54 PM
you could try using Testors glue for clear parts (basically the same stuff as Krystal Kleer) or you can use Future to make the windows.
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    August 2005
Posted by EdGrune on Friday, November 11, 2005 12:42 PM
Check http://www.evergreenscalemodels.com/Sheets.htm
Items 9005, 9006, 9007
    June 2003
Posted by Beau Mansfield on Saturday, November 12, 2005 2:52 AM
The best clear sheet made by Evergreen for windows:
Manufactured by Evergree Scale Models.
Ref No: 9005
Thickness .005" (0.13mm)
3 sheets in a pack.
This is excellent for windows and I have used it on all my large scale ship models.
I am presently building the same model of the USS Nimitz as you are.
Regards,
Beau.
    November 2003
Posted by Mike F6F on Saturday, November 12, 2005 8:54 AM
Montana,
Those island windows are heavily tinted green. When backlit by the sun the green tinting is very obvious. You may want to consider backing the clear styrene with some green photo gel filters, etc.
"Grumman on a Navy Airplane is like Sterling on Silver."
    June 2005
Posted by MontanaCowboy on Sunday, November 13, 2005 11:23 AM
Yes, I will be tinting them. I'll dip it in future+green food coloring
