Dockyard model HMS Prince 1670 (pictures)
    January 2005
Posted by bryan01 on Friday, September 8, 2006 1:34 PM
Hello all,
After asking so many questions and receiving even more great answers I thought it was about time to show you people what I’m working on.
I’m trying to convert the 1:180 Airfix HMS Prince 1670 into a dockyard model. My big example for this is the beautiful model in the Science Museum Kensington.
A special feature of these kind of models – apart from having only partially planked decks – is the stylized depiction of the underwater hull. By leaving of the planks between the lowest whales and the keel one gets a good view of the construction of the frames. These frames however are not represented as they would have been in the real ship but are arranged in such a way as to clearly show the rising-line and overall shape of the hull.
I started work on this model in early August by sanding the insides of the hull with a Dremel tool thus removing all raised detail and opening the gun ports and windows. After that I sanded away the raised plank detail and the lowest whale on the outside of the hull. The openings in the hull were indicated by using strips of 3 mm wide tape.
After determining the location of the rising-line the excess tape was removed.
Finally the 182 openings between the frames were cut out by hand. After one hull half was done I altered the location of the rising-line a little bit. This is how the hull looks at the moment.
More pictures will follow as building progresses.
Thanks for watching,
Bryan
    February 2006
Posted by GeorgeW on Friday, September 8, 2006 1:56 PM
I'm impressed Bryan, what an innovative conversion of an Airfix kit, I shall watch your project with interest.
Well done.
Posted by millard on Friday, September 8, 2006 2:47 PM
Bryan
     last year at the IPMS Nats in Atlanta.A modeler used the Revell Bounty kit to build a Dockside model.He didn't have mast just the hull it was pretty cool.Good luck keep the photo's coming.
Rod
    December 2003
Posted by scottrc on Monday, September 11, 2006 7:20 AM
Very interesting approach, I can't wait to see the finished results.
Scott
