? 1/72 revell Atlantic sub
    June 2005
Posted by smokinguns3 on Monday, October 9, 2006 2:54 PM
I mostly build A/C and the ocasinal boat or ship yesterday for my B-Day i picked up the revell germany atlantic sub ive biut the first one but this time id like to open up those holes in the hull what ever they are called. What i need to know is witch ones to open up all the books i have dont really show anything, i know i need to use my dremel to thin the plastic and ill use my pinvise to open them up. So if you all could help me out  with witch ones to open id really be happy and apreciate it.
Thanks in advance
Rob
Rob I think i can I think i can
    May 2006
Posted by waste gate on Monday, October 9, 2006 3:08 PM
    June 2005
Posted by smokinguns3 on Monday, October 9, 2006 4:21 PM
Thanks waste gate that should help out a bunch.
Posted by Anonymous on Tuesday, October 10, 2006 11:13 AM
Would a Dremel be able to open up the oval shaped holes?
I also have this model and haven't started on it yet but I was planning to use a dremel drill for the round ones. Not sure how to address the oval ones and keep a straight edge between the curved ends.
    August 2005
Posted by EdGrune on Tuesday, October 10, 2006 11:38 AM
You want to grind/thin the backside of the holes to start.    A Dremel with a ball-shaped steel cutter is good for this.   Leave a thin cover (+/- 0.010") of plastic on the backside of the hole then open & clean up with an Xacto knife.
