A Little Help with WEM Painting
    April 2005
Posted by cruichin on Saturday, February 24, 2007 10:06 AM
Hi All,
I've been an acrylics only guy until yesterday when I sprayed my first WEM 507B on a test KGV 1/700 model. I thought the paint was a little thick out of the tin, so I thinned with a couple of drops (approx 1:4 volume) with MM thinner. Thirty-six hours later, the paint is still tacky to the touch. I painted in a room temp, low humidity environment. Is this normal, or did I screw the pooch with the thinner? Is there a better way to use the paint - the color (colour) is great!
Thanks,
Steve
    August 2005
Posted by EdGrune on Saturday, February 24, 2007 10:40 AM
See John Sheridan's article on Colourcoats paints at SteelNavy.  In it John compares different thinners.
http://www.steelnavy.com/wem_colourcoats.htm
In this instant gratification world, I too have noticed a slight slowness in the paint to harden if my mix is off.  But with practice I have found that CC paints spray very well,  cover, dry, and have an excellent choice of color accuracy
    May 2004
Posted by CODY614 on Saturday, February 24, 2007 10:54 AM
Isnt' "Model Master Thinner" 'Enamel Based???'
Thinning:
These paints can be thinned with regular paint thinner, Mineral Spirits, or Lacquer Thinner."
That comes from the 'WEM' site.
Enamel thinner and lacquer paints dont' mix.At least I could never get it too work?
Also...He stated he had seperation in a month,after thinning...Maybe thin only what you are going to use in that sitting?
Jeff
Deep in the heart of a war, God heard a Soldier's Prayer.
    April 2005
Posted by cruichin on Saturday, February 24, 2007 12:22 PM
Thanks, Ed, once again, you come to the rescue!
Steve
Posted by Anonymous on Saturday, February 24, 2007 2:33 PM
I have used WEM paints with great sucess. One thing that you must do is to STIR the paint VERY, VERY Well. Not just shake the tins. I used Model Master thiners and they worked very well.
Have fun. I hope this helps
    April 2005
Posted by cruichin on Sunday, February 25, 2007 10:16 AM
I thought I'd mixed it well enough, but the finish is glossy, which the article said indicates not enough mixing. Just shows how great this forum is!
 Steve
