Need very thin plastic strips or sheets for 1/350 Yamato model
    April 2004
Posted by Chuck Fan on Tuesday, May 29, 2007 1:51 AM
I need very thin plastic strips to model the overlapping plate joints on hull side and torpedo blister. The hull plating is less than 1" thick, which in 1/350 works out to about 0.075mm. I tried Plastistruct's 0.3mm strips, but visually they appear unrealistically thick. I think 0.1mm would look close enough. Does anyone know of any source for really thing plastic strips or sheets? I could not find any Plastistruct catalogue, and my local hobby shop doesn't have anything less than 0.3mm.   Does anyone know where I can find a Plastistruct catalogue, or another source that might offer plastic sheets less than 0.3 mm thick?
    August 2005
Posted by EdGrune on Tuesday, May 29, 2007 6:43 AM
Evergreen makes styrene sheet in thicknesses down to 0.005"  (five thousandths) -- that works to 0.0127 mm.   Their 0.010 (ten thousandths) should work to be about 0.254 mm (2.54 * 0.010).
    May 2006
Posted by Tug Guy on Tuesday, May 29, 2007 7:56 AM
Would tape simulate the plating?
Tug
    April 2004
Posted by Chuck Fan on Tuesday, May 29, 2007 11:13 AM
Tug
Yes, but I have concern about drability of paper or tape for this usage.
    October 2004
Posted by ikar01 on Tuesday, May 29, 2007 3:20 PM
I have a piece of plastic approx 3 1/2 X 11 that I had miced down by somebody at work.  I was told that it came out to 1mm.  Would this work?
    April 2005
Posted by ddp59 on Tuesday, May 29, 2007 7:38 PM
you'll want the .010" or .25mm. how about those signs that say private property or something like that?
    October 2004
Posted by ikar01 on Tuesday, May 29, 2007 7:48 PM
If Chuck wants it I'll give it to him.  I've have it for about 20 yearn and have no use for it.
    February 2006
Posted by Wilbur Wright on Tuesday, May 29, 2007 9:17 PM
I've had good luck with Evergreen material of all shapes and sizes on ship models.........the only thing to watch out for is thin material melting into a glob from your styrene glue/welder. I use Tenax sparringly.
    October 2004
Posted by ikar01 on Tuesday, May 29, 2007 10:40 PM
or super glue.
