Aaargh! Matching bottle color to spray color?
    March 2004
Posted by Gerarddm on Thursday, June 14, 2007 12:52 AM
Found a pefect Model Master enamel, FS30117 Military Brown, to do the wood deck on my 1/700 Yamato. Problem is, hand painting made it look too splotchy. I can't seem to find a spray can color to match, any suggestions? The primer is light gray enamel.
BTW, would hitting the deck with some dullcoat clear even out the splotchiness ( is that a word)?
Or any suggestions for re-stripping, and a different hand-painting technique for an even finish?
Thanks-
Gerard> WA State Current: 1/700 What-If Railgun Battlecruiser 1/700 Admiralty COURAGEOUS battlecruiser
    April 2005
Posted by T_Terrific on Thursday, June 14, 2007 12:07 PM
How about stripping it and spray-painting it with the MM product?
Tom Cowboy [C):-)]
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
    March 2004
Posted by Gerarddm on Thursday, June 14, 2007 1:52 PM
Tom, don't have an airbrush and that particular MM color isn't available in spray cans.
    February 2006
Posted by Wilbur Wright on Thursday, June 14, 2007 10:46 PM
No ....flat will not help even it out....however there is no reason you can't get a good finish for a deck in that scale using a brush..................wood decks have many tones, and will look more realistic if you vary the tones slightly from the base color, over different light coats.
Try to experiment on a piece of scrap plastic. Base coat brushed on first, then some varying of color, here and there on the deck.
<> Use good red sable brushes!
Others chime in....
    February 2006
Posted by Wilbur Wright on Thursday, June 14, 2007 10:49 PM
BTW my Yamato in 350th scale has a much more (yellow woodish ) tone to the deck. Then weathered.
