New to ships
    October 2005
New to ships
Posted by sawdeanz on Wednesday, December 19, 2007 2:42 PM
Hey all,
I have some experience in armor and aircraft, and am working on a big scale helicopter right now, but I was interested in starting in ship models as well. I'm interested in battleships and the like. What advice could you guys give me? Is there anything different about ships than armor or aircraft that I should know about? Are there any essential or special tools I might not already have? What scale should I start in? 1/350 or 1/700? I wanted to try making the USS indianapolis, which I can find only in 1/700. Would you say that the bigger scale or the smaller scale would be easier for the ship beginner? Thanks ahead of time for your help and advice.
    August 2005
Posted by EdGrune on Wednesday, December 19, 2007 2:58 PM
I recommend that novices to ship modeling start in 1:350 then transfer the skills learned to a smaller scale [if they wish to go in that direction].
I also recommend that instead of starting with a big (read expensive) kit such as a battleship ot carrier that they begin with a destroyer-sized project.   For that I recommend the Tamiya Fletcher, the Trumpeter England, or the Revell SMS Emden.
I recommend the larger kits because the parts are larger and easier to learn to manipulate.
I recommend the destroyer-sized project since there are fewer parts (less of the Ohmigosh! Factor) than in the larger (expensive) kit.   This kit will more likely be finished than the bigger kit which gets put away for fear of screwing it up.
There are no styrene Indianapolis kits in a larger scale.  It is only available in the smaller scales.   There are some 1:350 scale cruisers due soon, from Trumpeter.   I would recommend that you hold off until we see how they are.   Trumpeter's ship kits have been hit-n-miss as far as quality is concerned
    October 2005
Posted by sawdeanz on Wednesday, December 19, 2007 5:56 PM
Thanks, that sounds like good advice. I was considering 1/350 scale but was dettered by the price tags, so I'll take your advice and start with the smaller destroyers.
    January 2007
Posted by peterj on Wednesday, December 19, 2007 6:42 PM
I'm a 95% aircraft guy myself, so I know where you're coming from.  Ed's ideas are spot on.  Definitely start with 1/350, unless you're a 1/144 or 1/200 aircraft modeler.  Start with something relatively small and simple to learn new skills.
Right now I'm working on the Trumpeter 1/350 SS Jeremiah O'Brien Liberty Ship, with GMM PE.  It's been a long time since I've done a ship, so I'm a bit rusty, but it's coming back.  My biggest hurdle is that I'm fairly illiterate when it comes to ships, so I really have to work to figure out where some of the PE goes.  If you can find online pics of your subject, that'll help a lot in this area.
There's also a suspiciously long, narrow box under the tree that just might be a USS Hornet.  That would combine my air and ship interests nicely.
Peter
    October 2005
Posted by sawdeanz on Wednesday, December 19, 2007 8:20 PM
lol, I sure hope santa brought you just what you wanted ; )
    March 2007
Posted by JMart on Wednesday, December 19, 2007 8:32 PM
sawdeanz - I was in the same "boat" (pun intended) as you.... I got similar answers when I researched what to build first. The Tamiya 350 Fletcher is the most popular choice, as mentioned in the above posts. Other ships to consider would be 1:700 flatops; still a managable size, not as much superstructure, you can try some detailing. Another one to consider is the good ole (or just old) CHEAP Revell PT109 boat (1:72). Large and a relatively quick build. The Liberty ships from Trumpeter arenot really for novices, but a great choice if you want to steer away from "guns". For modern ships, stick to destroyers, the Dragon USS Kidd comes well reccomended, will set you back 30-40$. In terms of "tools", you will end up doing PE for sure, including long rails. I am saving for a PE bending tool... finally, down the road you will probably want to switch to resin ships, 3x the cost, 10x the quality, 100x the choices and types. Dragon has released a nice series of 1:700 ships, "Premium" editions, which includes PE. I have a couple of their destroyers, small but not minuscule. Think "1:72 scale WW2 twin engine bomber". Still "large enough" for details and look nice, can be had for less than 20$. And steer clear from Trumpeter UNLESS you research the SPECIFIC kit... the variety of quality is immense....  hope this helps!  Oh one more thing, you will do a lot more of "hand painting" (vs AB) in ships vis-a-vis a/c and armor. As mentioned before, I would recommend to wait on the battleships and 350 scale a/c carriers.
    March 2007
Posted by searat12 on Wednesday, December 19, 2007 8:56 PM
Well, if you are really fixated on a 1/350 battleship (though the advice elsewhere about a 1/350 destroyer is good to think on!), you might have a look at either Bismarck or Yamato, of which there are inumerable examples available for cheap money (like around $30).  There is supposed to be a new Bismarck kit coming out by Revell of Germany that appears to be a real winner, and cheap too!  I suggest either of these battleships because both have been produced in profusion, there are tons of different PE and other 'upgrades' that you can add to the mix, and basically make it as tough for yourself, or as easy as you like.  The main point is that both of these ships have relatively few parts compared to others, with large painting areas, simple paint schemes, and make very presentable models at the end of the day.
    January 2007
Posted by peterj on Thursday, December 20, 2007 10:41 AM
Judging from the evidence, it's a pretty safe bet:
1) It's not wrapped
2) I bought it myself - 40% off at the local craft store.  Now I can afford the extra B-25s and some PE Thumbs Up [tup]
Peter
    August 2005
Posted by EdGrune on Thursday, December 20, 2007 2:49 PM
I cannot recommend the Trumpeter USS The Sullivans destroyer in 1:350 scale to a novice.  There are several problems with the kit which would make for a less than satisfactory first build (fit, over and under-sized parts).
Modern destroyers such as a Burke or Spruance class are larger than WWII destroyers, as large as WWII cruisers.   I was recommending a smaller kit -- something which will be completable.  Also a WWII destroyer would likely have more/varied assembly tasks to practice.
    October 2005
Posted by sawdeanz on Thursday, January 3, 2008 10:31 AM
Update:
Sorry I haven't gotten back to you sooner, but since then I went out and got a kit with my christmas money. I wasn't too concerned with the subject, so I just visited the lhs to see what interested me. Well, I fell for the Glencoe Models 1/225 scale USS oregon. Its a pre-dreadnought battleship, in fact its like the first battleship, so it is not an especially large ship. It is most known for its record voyage around the tip of South America during the spanish american war in order to join U.S. forces and it participated in the attacks there (there was no Panama canal then). The scale is larger than usual making for an impressive model. I know you guys told me to go with a destroyer sized project, but this is a small battleship. Anyways, its large enough model wise to be an easy build. Curious, I tried to find any after market details but the PE fret cost as much as the model did, so I will have to skip that this time, although I would like to at least add railings, any suggestions for this?
Thanks for all your advice. I'll Post pictures when i finish.
---Sawyer
    August 2005
Posted by EdGrune on Thursday, January 3, 2008 11:09 AM
 sawdeanz wrote:
...<SNIP> ... although I would like to at least add railings, any suggestions for this?
Unfortunately you chose a subject which does not have a great deal of afternarket support vis-a-vis separate railing stock.   You can find it in 1:200 scale, but not in 1:225 scale without going to a set dedicated to the subject.  You may find that using these mixed scale items will result in a visually jarring image.
Plus you chose a model which is old (the kit, not just the subject).   The parts engineering, molding, and fit are not up to today's standards.  The molds are worn out -- lots of flash & misshapen parts.  The kit can be made to look quite nice, but not without a great deal of destruction and scratchbuilt replacement items.   Not something for a NOOB.
The kit engineering and aftermarket support was the prime reason for the recommedations I made.   My recommendation now,  build the kit but do not sweat adding the additional time, effort, or expense of aftermarket items.   Count it as a learning tool and move on
    January 2006
Posted by EPinniger on Thursday, January 3, 2008 3:32 PM
Although the Glencoe Oregon can be built into a beautiful and impressive model, I would agree with EdGrune that it is not for a beginner - even if you have a complete aftermarket PE set, there are still some missing details that need adding/scratchbuilding (turret roof vents, boat oars, etc.), modifying/reworking many of the plastic parts to add PE detail requires a fair amount of skill, and most of the kit parts require a lot of cleanup, sanding, filler etc. Basically wait until you've got a reasonable amount of experience working with PE and making simple modifications and scratchbuilt additions to styrene parts with Evergreen etc.
For reference, photos of the 1/48 Smithsonian museum model (available on the Internet, can't remember the URL but a Google search would probably find them) will help. An old issue of FSM (can't remember the year - 2002?) also had a good article on detailing the Oregon.
However, if built "out of the box" it'll still look quite nice, particularly if you add railings - but the poorly moulded parts (lots of flash/mould lines to clean up) and poor fit might be frustrating.
Regarding the railings, 1/200 scale would almost certainly look OK, for a start the scale of the kit is actually slightly larger than the  "1/225" on the box (something like 1/215), secondly, unless you know exactly how tall the original railings are supposed to be, the 7% approx. height difference won't be very noticeable - IMHO at least.
Another tip - the Tom's Modelworks PE set is MUCH cheaper than the Gold Medal one, although the latter has the advantage of also including parts for the Revell USS Olympia.
A good choice for a first "pre-dreadnought" battleship would be either Zvezda's "Borodino" (Imperial Russian) or Hasegawa's "Mikasa" (Japanese) - these are a significantly smaller scale (1/350) but being much newer toolings have much better fit, accuracy and detail. Zvezda's "Varyag" and Revell's "SMS Emden" are excellent kits of cruisers from the same era, also in 1/350.
    March 2007
Posted by JMart on Thursday, January 3, 2008 5:46 PM
Having "been there done that" I will "ditto" the above two posts. If you want to build a circa WWI and/or pre/dread types, the two examples mentioned above are much more accesible for a newbie (of which I am one!). I picked up the Zvezda 1:350 Oriol (Russian Borodino class BB) for $20 at SprueBrothers.com (look in the NAVAL BARGAIN BIN). The Revell 1:350 Emden (a large cruiser) is even cheaper, 10-12$ depending on which web site you look (GreatModels.com another good one). I would humbly suggest to shelve the Oregon and pick up one of the above (or one suggested in previous posts)...hey we ALL have stashes... I have opened couple kits, decided Im not up to speed and close them up for later...:).  Good luck either way and enjoy your build!
    March 2007
Posted by searat12 on Friday, January 4, 2008 12:53 PM
Yup, I agree with all of the posts above about the Oregon.... Mikasa is an excellent build (but an expensive model!!).  A cheaper alternative might be one of the (many!!) Yamatos that are out there in 1/350.  If you are really hung up on big pre-dreadnoughts, the protected cruiser 'Olympia' is also a good subject which has been produced many times by a variety of model makers.  Best is if you can get a hold of one of the old ones by Pyro on Ebay, since the moldings are better than more recent editions (unless you want spend REALLY big bucks on a resin kit!!)
    October 2005
Posted by sawdeanz on Friday, January 4, 2008 3:31 PM
I hear what you guys are saying, and I appreciate the advice. I'm going to go ahead and build the oregon out of the box and do my best with it. I've already started and have got the major parts together (the hull halves, the deck, and the superstructure base). I may have jumped into a difficult build unknowingly, but I'll do my best to make a clean finished model even if it lacks some detail. Then I'll save up some money and get one of those WWII destroyers you all recommended. Since I don't have any experience with PE, the destroyer will be my first shot, and I won't worry about PE detail on the Oregon. Thanks again for your time and advice. Wish me luck!
    October 2005
Posted by sawdeanz on Friday, January 4, 2008 3:55 PM
Here are some pics of the model so far. Obviously, it still needs a lot of cleaning up, mostly around the seam where the superstructure decks and the side superstructure wall pieces join together, the fit there was really bad. I've spent a lot of time trying to fix that seam and my hacking job on it may be hard to clean ( see 3rd photo) On the underside, there were some weird sink marks which I filled, and that is about as far as I have gotten. Oh, also I drilled out the portholes.
    March 2007
Posted by bondoman on Friday, January 4, 2008 4:40 PM
I just built my first ship in a long time, the Revell USS Pine Island. It wasn't very expensive on eBay, and it was fun because it had an aircraft, and I'm not so much a gun guy. I bought the expensive GMM fret, but it also has enough to detail a San Juan Capistrano tanker, plus maybe a third model, so it worked out to less than $ 20 per ship and it really adds to the model.
I did spurge on a PE bender, but I'm always one for investing a little in good tools and it works for my RR and wingnut hobbies as well.
The water is funky, but I had a blast and got good advice here. I've since made the sea flat and am looking forward to building the tanker "under way". I really like the people on this forum- no snarky.
    March 2007
Posted by JMart on Friday, January 4, 2008 6:57 PM
sawdeanz - good luck on the build! I have not build that model myself, here are couple web pages with build info:
http://www.modelwarships.com/reviews/ships/bb/bb-03/350-jb/jb-review.html
http://www.cybermodeler.com/hobby/kits/glen/kit_glen_oregon.shtml
Seams are a pain... I have gotten better luck with Tenax (plastic welder) than with liquid cement when it comes to gluing 2 "halves" of any cylindrical object.
bondoman - I remember your ship from the Revell GB (Im still finishing mine, past deadline, shh!)... what PE bending tool do you use? I will get one next month or two, starting to do some research on the subject...
    July 2013
Posted by DURR on Saturday, January 5, 2008 6:06 PM
your a bit rusty you say  well don't forget to apply some of that rust to the o'brien
    November 2007
Posted by u-boater on Thursday, January 10, 2008 2:05 AM
Looking good so far!
Take your time and don't get too stressed over the construction/details.
There are a lot of experienced people here with a lot of talent and know-how.
You'll get great advise and tips to help you along.
I look forward to following your progress!Make a Toast [#toast]
www.resinilluminati.com
    October 2005
Posted by sawdeanz on Thursday, January 10, 2008 8:52 PM
of course with midterms coming up for me, I haven't gotten much more done. But i have cleaned the seams since and have started adding parts to the superstructure. I even drilled out the gun barrels a little and all the portholes, so I felt proud about that. I guess I'll see how the drilled out holes look when I paint it, cuz i just did it by hand with a micro drill thingy.
Does anyone have a rigging diagram they can scan for me, or does anyone have any links because the directions have no directions for this except for the box cover art. Also, I suppose I'll have to search the forums for rigging techniques as this is something new to me... But alas, I should go do some more studying...
---Sawyer
    March 2007
Posted by JMart on Tuesday, January 15, 2008 10:16 AM
Cant help with rigging, never done it... did you search this site? I have found answers to almost every question I have posed by searching.. plenty of info on here, good luck!
    May 2006
Posted by zipmeister on Tuesday, January 15, 2008 1:35 PM
Hi all
I'm sorry sawdeanz I don't mean to steal your thread, but I too am curious about build a ship. Could I get an opinion on the Dragon Arleigh Burke as a first ship model. I have a friend that is willing to trade an aircraft model for it.
    March 2007
Posted by JMart on Tuesday, January 15, 2008 1:47 PM
 zipmeister wrote:
Hi all
What scale? search of this site gives following threads:
/forums/297010/ShowPost.aspx
/forums/297006/ShowPost.aspx
/forums/747821/ShowPost.aspx
hope this helps, I dont have it, but Dragon 1:700 Premium kits get high marks everywhere
    May 2006
Posted by zipmeister on Tuesday, January 15, 2008 1:58 PM
I'm sorry the scale is 1/350
Zip
    March 2007
Posted by JMart on Tuesday, January 15, 2008 2:08 PM
350, that thing is huge, I have a USS Kidd in 350, great kits, takes a bit to build
here is a review link
http://www.ipmsusa2.org/Reviews/Kits/Ships/dragon_350_arleighburke/dragon_350_arleighburke.htm
    August 2005
Posted by EdGrune on Tuesday, January 15, 2008 3:21 PM
 zipmeister wrote:
Hi all
As a first ship model it is OK.  Its big.  Its its modern, Its gray.  Its boring.  It will give you some good experience in applying railings.   White Ensign and Flagship make photoetch sets.   Either are good, but you may get frustrated over the small hoohahs on the mast.  You also miss the learning process of the secondary & tertiary guns (a'la the Fletcher).
A note on the pedigree of the Dragon kit.   It is the old Panda Models kit.  Its hull is covered with bumps.    These are supposed to be the inhaul padeyes, used for clipping the over-the-side maintenance platforms close to the hull.   They should be small U's   Cut & sand them off.
The flight deck has huge ridges (somepeople call them painting guides).   These need to be sanded flush.   No helicopter could land on the rough terrain of the flight deck
The bilge keels are also too big.  They need to be removed (filled) and replaced with some sheet stock.  I have the kit -- and I can't really remember if there are any facilities for making a waterline model - short of taking it to a belt sander
    May 2006
Posted by zipmeister on Tuesday, January 15, 2008 5:37 PM
 I also had my eye on the Tamiya 1/350 Fletcher. I take it this may be a better kit? I really appreciate the feed back! I'm sure my first ship model will be OOB because I too notice the PE sets are priced at or more than the ship itself. I want to make sure I will enjoy building a ship first.
Zip
    March 2007
Posted by JMart on Tuesday, January 15, 2008 6:42 PM
I think the "consensus" seems to be that the tamiya fletcher 350 is one of the best, if not THE best, "first ship" to build. Not that I ever followed by OWN advice, ended building the REvell PT109 out of sentimental reasons, and lets just say I have been practicing putty filling and flash sanding a LOT lately. I was also told that a 1:720 scale modern aircraft carrier is a good choice; you can build as simple or complicated as you wish, not as much superstructure to worry about. I have an old Monogram Nimitz on the bench laughing at me at the momment :)
good luck, cheers, Jim
    August 2005
Posted by EdGrune on Tuesday, January 15, 2008 6:54 PM
Zip
I just picked up the Fletcher Class Destroyers book by Lester Abbey.  It is in the ShipCraft books line.   Abbey echos my sentiments about the 1:350 Fletcher by Tamiya.   He says of the Tamiya " ... the best Fletcher kit on the market.  ... well researched ... great amounts of lovely detail,  fits together beautifully ... nicely moulded ... no flash or sink holes."
Abbey describes the Trumpeter The Sullivans as disappointing and decidedly mediocre.   For the Lindberg Blue Devil he compares it to the story of the axe.  "It was a very good axe after I replaced the blade, then replaced the handle."
Abbey's book is primarily a summary.  It summarizes the design and operational histories of the class.  He summarizes the armament evolution through the war.   He summarizes the camouflage measures applied.  For detailed information go to other sources,  the Squadron book,  NAVSOURCE, DestroyerHistory.com, etc.  I wouldn't hang my hat on the color plates for the camouflage measures.  They don't look blue enough to my eye.
What the book does have and presents well is a review of the kits of the Fletchers by the major manufacturers.  He also includes the major aftermarket PE & resin suppliers.  He did miss the L'Arsenal set which came out after publication.
I'd recommend the book to supplement an existing library of Fletcher information
