Destroyer decks level with top of hull?
    January 2007
Posted by belcher on Saturday, December 22, 2007 9:16 AM
Hya,
I'm builiding the Lindberg Blue Devil Destroyer kit, and I wondered if the deck is supposed to be level with the top of the hull. My research pics show it that way, but the holding tabs for the deck on the model would have it significantly lower. Any advice?? Can this kit be built as the USS Sorley DD 707?
thanks
    February 2005
Posted by billydelawder on Saturday, December 22, 2007 9:42 AM
I've not heard very good things about this particular kit.  Soley was a Sumner class destroyer, witih 3 twin 5 inch mounts instead of 5 singles.
    January 2007
Posted by belcher on Saturday, December 22, 2007 10:47 AM
Thanks. More info?
    August 2005
Posted by EdGrune on Saturday, December 22, 2007 1:23 PM
 belcher wrote:
Thanks. More info?
The Lindberg "Blue Devil" is supposed to represent a Fletcher-class destroyer.  The Soley (DD707) was of the Allan M Sumner-class.   There are minimal differences between the hulls of a Fletcher and a Sumner.   The extigencies of wartime contruction mandated the similarity of the hull & machinery so as to minimize the retool impacts to production.
http://www.navsource.org/archives/05/707.htm
The Fletchers were armed with five 5-inch/38 caliber single guns.   The Sumners were armed with three 5"/38 twin guns.   There are also differences between the two classes in secondary armament layout and in the deckhouses
You can make a Sumner out of the Blue Devil, but be prepared to discard the kit superstructure and rebuild everything from the deck level up.   To do that project I would recommend the Floating Drydock's Plan eBook
http://floatingdrydock.com/update.htm
Before you get too deep in the Blue Devil project you may be interested in reading Jeff Herne's article on SteelNavy describing his build of the kit.  It is titled 'Trial By Ordeal' if that gives you any hint as to what is before you.
http://www.steelnavy.com/BDFletcher.htm
And to answer your original question,  the deck edge should sit flush with the side of the hull.  Shim it up to level
